diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   European Transistors Equivalent Search (http://www.diyaudio.com/forums/solid-state/53346-european-transistors-equivalent-search.html)
Algar_emi 12th March 2005 05:23 PM
Hi. Ièm looking for the american (digikey) part number equivalent of the following european transistors:
BC546B
BC556B
BC639
BF256A
Can someone help me on that?
Thanks...
sajti 12th March 2005 05:59 PM
Re: European Transistors Equivalent Search
BC546B
BC556B
BC639
BF256A
Thanks...
I'm sure, that Onsemi makes the 546/556, and the 639....
sajti
moamps 12th March 2005 06:14 PM
I usually use these substitutions:
BC546/556 --- MPSA06/56 or 2N5401/5551
BC639/640 --- MPSA43/93 or 42/92
BF256 --- jfet ----depends on the application
Milan
Algar_emi 12th March 2005 08:29 PM
2 Attachment(s)
Great help, very appreciated.
Here the application for the FET. It is an amp protection circuit.
I think it is use in this circuit as a current source for T35,T36.
So what is your recommendation on this?
Thanks.
moamps 12th March 2005 09:32 PM
The closest replacement (RF characteristic) for BF256 in digikey catalog is 2N5486. However, in this application almost any N ch jfet with Idss around 5mA will be just fine, IMO.
It is Elektor's THE AMP?
Milan
ilimzn 15th March 2005 07:39 AM
The transistors used really do not seem critical at all in this circuit.
Perhaps the easyest thing would be to use MPS8099 and MPS8599. Just be careful when replacing the BC639 as the pinout is different.
jaycee 15th March 2005 10:18 AM
You could replace the FET arrangement with any current sink, as this is all it is doing. You could make a current sink with 2 transistors or 1 transistor and a 3mm LED quite easily (look at the LTP of pretty much any amplifier to see how this works)
princenzekwue 27th September 2010 01:07 PM
Please can any body on how to get MPSA06 TRANSISTOR and TIP42S for my Hydrotrac echo sounder panel. Cant find any around Nigeria.
Copyright ©1999-2017 diyAudio
