Another quasi-complementary design - Page 64 - diyAudio
Old 3rd January 2013, 04:40 PM   #631
dudaindc's Avatar
Originally Posted by Idefixes View Post
In order to power a subwoofer i planed, after been fully pleased with BOQ, to use Artck with +/-70Vdc rail and 8xIRFP450 unit in output stage. I redrawn Quasi borad for MPC071 resistor use in output stage and put DC protection relay on board. Next stap after one more checking will be board etching.
Marc
Pretty nice - I may follow your footsteps...
I hope all goes well with your project.
Cheers!
"All measurements are wrong! Thus, measurement is the art of handling errors."
Old 4th January 2013, 09:05 PM   #632
Default NMOS350
Hey. I'm from Slovakia and I do not know English. I use only Google translator. I want to ask whether the author NMOS350 by Quazi. I built one piece of editing and I'd send it over. Involvement and the measurement. If so, I will ask you if you're an author, write me a mail at maduda.radoslav @ gmail.com.
Via mail to communicate better.
thank you
Old 2nd December 2015, 10:38 AM   #633
Dear Idefixes, Can you post Sprint file of this layout?
Old 2nd December 2015, 11:31 AM   #634
Idefixes's Avatar
Send a message via ICQ to Idefixes
Layout is under Eagle...
Marc
website : http://audiyofield.wifeo.com/index.php
Old 17th December 2015, 03:40 PM   #635
Has any one constructed scaled down version of famous Acktrk amplifier with only one pair of Mosfet. If yes please share the layout and the circuit with revised components values.
Old 17th December 2015, 03:57 PM   #636
Idefixes's Avatar
Acktrk is a PA typed amplifier, i don't think there will be many concern to a one pair version....
Marc
Old 21st December 2015, 10:32 AM   #637
Dear Quasi,
Can we not device some method to prevent Aktrk600 mosfet amplifier from self destruction due to thermal run away. Can T5 transistor which is being used as diode be replaced with NTC thermistor so that in the event of high temperature, the drive to T4 is reduced.
I want to construct this amplifier but am I am afraid from damage of MOSFET transistors as these are still expensive here in India. Long time back similar topology MOSFET amplifier was published by Elektor which used Siemens BUZ mosfets here NTC was used for thermal protection. Your valuable suggestions will help many constructors of this amplifier since you have designed it. Awaiting your reply.
Old 22nd December 2015, 10:40 AM   #638
I think BUZ are Lateral mosFETs.
Quasi's designs use Vertical mosFETs and one uses BJT.
T4 provides temperature compensation for the T5 current.
Your proposal of replacing T4 with a thermistor completely changes the operation of the tempco.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 22nd December 2015, 12:54 PM   #639
No Mr AndrewT, I did not mean this. I want to reduce the drive of T4 by putting a parallel NTS to T5 which is used as diode here. Please comment if my interpretation is correct or not. The Siemens circuit did not use lateral MOSFET's it used BUZ23.
Old 22nd December 2015, 01:46 PM   #640
T5 is not used as a diode.
I see T4 used as a diode.
Do you have the datasheet for the BUZ23?
regards Andrew T.
quasi-complementary output Vlad Pass Labs 4 13th April 2010 12:07 PM
quasi complementary old school design rtill Solid State 3 11th August 2009 03:29 PM
Quasi or full complementary. pro Solid State 7 14th September 2004 09:26 PM
Copyright 1999-2017 diyAudio
