#11 |
Hi quasi again!
I have one general question to you: I've been always a bit suspicious about driving mosfets like this, it seems to faster swith-on then swith-off (it looks like a bjt-current-source for 'on' vs. 220resistor for 'off'). Have you considered additional emitter follower stage? cheers |
#12 | |
Hi buddy, IF i am not wrong , when the spike is present and as it goes to the upper mosfet , in every case the zener will clamp it to 12V if +ve with reference to VGS or to 0.6V if -ve with reference to VGS. Acc to me there is no need for extra diode in series. PLease correct me if i am wrong. regards, kanwar
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#13 |
Hi quasi!
Nice design, I'm interesting to build it! My only problem is the loss on the positive swing. As I count, there is 4.7V on R4 and R9. The Vgs of the IRFs, is about 6-7V with the peak current. This means that You can get only 39-40V peak on the posisive half of the output signal. This looks serious power loss for me sajti |
#14 | |
Hey darkfenriz; Yes in my other design in the thread "Power Amp Under Development" I run a 2nd driver stage that is controlled by the second constant current source. With a very similar cct to this one though I have not noticed any problems with the output drive. The second stage constant current source of around 36mA (18 mA per side) is a sufficiently low "impedance" to turn the FET on and 220 ohms should discharge the gate quickly too. There are probably differences between the turn on "slew" and the "turn off" slew but in practice on a similar cct even the square wave response doesn't seem to show anything bad. Cheers
http://sites.google.com/site/quasisdiyaudiosite/ |
#15 | |
Yes you are right of course. The 4.7v is necessary to provide enough voltage for the second constant current source (T5) to work properly. If you cut the track between C8 and R17, you can run the top left hand side of the amp with an additional 10v. This will provide sufficient voltage to drive the positive output stage to close the 50v rail. Here is the revised cct. Cheers
#16 |
thank you for reply!!
if I could ask you for further sharing of your knowledge and experience: ftp://ftp.elektroda.net/download/Audio/Projekty/Wzmacniacz%20HiFi%20250W.pdf here is another (very similar topo) amp I found (sorry for it's in Polish) and resistors responsible for swithing off are 1.2k. For me it is asking for troubles, what do you think? |
#17 | |
sajti |
#18 | |
Did it Himself
quasi,
Thanks for the compliment You do not need to include a normal diode in the lower zener diode because there is absolutely no risk of current reaching up through it.Quote:
No, you must include the diode. As you say the voltage will be clamped at 12V, but surely it's far better to stop the spurious transients even being a problem. They will cause distortion.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#19 | |
By using the 1.2K this means that the drive current is only 3.3mA and this is too low I believe for good FET control. And the temperature compensation cct is very impressive, but I would never use it. It may do a better job than my one transistor (wired as a diode) but both will settle down to a consistant bias current. In any case +/- 10% in bias current is not important provided you still have plenty. Note though that in my cct if the sensing transistor is too far from the FETS .......kaboom! is a real possibility. Cheers
#20 | |
I'f I use the diode I will put on both zeners, only so that if they turn on under over-current conditions they do so symmetrically. The FETs have built in reverse diodes. Would these clamp back EMF sufficiently to reduce the problem? Cheers
| quasi-complementary output | Vlad | Pass Labs | 4 | 13th April 2010 12:07 PM |
| quasi complementary old school design | rtill | Solid State | 3 | 11th August 2009 03:29 PM |
| Quasi or full complementary. | pro | Solid State | 7 | 14th September 2004 09:26 PM |
