Another quasi-complementary design - Page 10 - diyAudio
Old 31st October 2005, 11:14 AM   #91
quasi is offline quasi  Australia
quasi's Avatar
Default And the tracks
The track side.
Also if you build the amp please make contact so I can offer some advice on setting it up (before you turn it on).
Good Luck & Cheers
Old 31st October 2005, 06:02 PM   #92
pejinm is offline pejinm  Serbia
pejinm's Avatar
It looks like it's something wrong with the attachment!?
I can't download it...
Old 4th November 2005, 12:05 PM   #93
quasi's Avatar
Default Dunno what happened with the attachments
....but I'll try again.
Old 4th November 2005, 12:07 PM   #94
quasi's Avatar
Default And the tracks ....
Please check against the schematic before building....
Old 4th November 2005, 12:20 PM   #95
quasi's Avatar
Default Aaaahhh Phooey....
The schematic posted earlier in the thread for the high power version is incorrect. The second constant current source transistor (T6) is shown connected in reverse. It is corrected in this schematic.
Sorry.......
Old 4th November 2005, 07:27 PM   #96
pejinm's Avatar
Thanks Quasi...
Old 4th November 2005, 08:08 PM   #97
Banned
Hey quasi My name is mastertech you are all very good quasis
i havent seen one of yours i havent liked
btw have you ever built a quassi running in class-a
thanks and out
Old 4th November 2005, 11:11 PM   #98
quasi's Avatar
Default Quasi class A
thanks and out
Thank you Mastertech.
No I haven't. No reason why this design could not run in class-a though.
Using the low power module the changes I would make would be;
1. Lowering the main rails to around 25 volts
2. Lowering the secondary rail to 35 volts
2. Shorting R7
3. Reducing the gain (R13 / R11)
4. Cranking the bias current up to 3 amps or so (ouch).
5. Big heatsinks (150 watts will be dissipated continously per module)
6. A huge regulated & noisless power supply capable of 6 amps. ( x 2 for stereo ).
Voila ...one 35 watt class-a amp.
The above is for a practical amp ....of course you could leave the rails as they are .....but I'm sure you have adequate heating in your home. Still it would be awesome.
Cheers
Old 5th November 2005, 03:17 AM   #99
Banned
thanks quassi
Old 5th November 2005, 04:34 AM   #100
Workhorse's Avatar
Hi Quasi,
have you encountered Thermal Drift in your amplifier...
regards,
K a n w a r
quasi-complementary output Vlad Pass Labs 4 13th April 2010 12:07 PM
quasi complementary old school design rtill Solid State 3 11th August 2009 03:29 PM
Quasi or full complementary. pro Solid State 7 14th September 2004 09:26 PM
Copyright 1999-2017 diyAudio
