Old 11th March 2005, 06:41 AM   #1
dan4 is offline dan4  United States
Default How do autoformer impedance matching controls work
I am in desperate need to understand how an autoformer based volume control works. Ideally, I would like to get my hands on a schematic. I helped a friend install four volume controls (installed in parallel using the x4 setting to present a combined 8ohm load). I am however perplexed how these controls work and need to understand to resolve a problem.
Any help is greatly appreciated. Thanks.
Old 11th March 2005, 07:21 AM   #2
the autotransformer will do both impedance matching and volume control. Which do you need?
For a volume control the autoT can provide either gain or attenuation or a range of both.
Consider an autoT with 5 wires; start, 25%, 50%, 75% and finish.
Connect the input to start and finish then the output can be connected to any pair but with no gain available.
eg. output s/25% gives -12db. s/50% gives -6db, s/75% gives -2.5db, s/f gives 0db. The formula is 20 * log(volt gain). If volt gain is less than 1 then the log will be negative. If you need to specify the transformer tappings then the reverse formula can be applied using the 10^x key on your calculator.
If you connect the input to s/50% then you can get gain (2 tappings) and attenuation.
For impedance conversion use the (volt gain ^2) * impedance to give the new impedance.
Maybe that is what you want, I hope I'm not trying to teach you have to suck eggs, Sorry if I have.
regards Andrew T.
Old 11th March 2005, 10:47 AM   #3
moamps is offline moamps  Croatia
http://www.rane.com/note136.html
my little calculation:
Old 12th March 2005, 07:51 AM   #4
Thank you. The wiring diagram provided is what I was looking to obtain. Much appreciated!!!
Impedance matching Triod lover Tubes / Valves 2 12th January 2007 09:59 AM
impedance matching to a pro amp... MyNameIsJake Solid State 2 4th June 2006 05:32 PM
Need help understanding transformer impedance ratios and impedance matching percy Tubes / Valves 5 28th February 2005 08:35 PM
impedance matching fragman56 Tubes / Valves 17 20th March 2003 02:38 PM
Impedance Matching bryce66 Solid State 6 9th November 2001 09:02 AM
Page generated in 0.07091 seconds (84.46% PHP - 15.54% MySQL) with 11 queries
