Check this device out and let me know if is good for Mosfet Amp.
How much power we can get with pair of these? Thanks. IRFP90N20D |
#2 |
According to the datasheet it's a "SMPS-Mosfet" for DC-DC converters.
Seems that it is fully designed/optimized for switching. Also, the 6nF inputcapacitance is not easy to drive. Maybe it's good for a multiple kilowatts ClassD ? Mike |
#3 |
Hi ZOX ,
Being a N-channel mosfet amp manufacturer, I think now its my turn to say something!. yes its a smps mosfet, but you can very well use this in Quasi-complementary amp. You have to design a good driver stage to drive this mosfet. the driver idle current must be at least 40-60mA in order to drive this huge gate capacitance along with good damping factor. You can draw upto 300WRMS @ 4 ohms just from a single pair very easily. regards, Kanwar
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#4 |
Did it Himself
I think you posted in a similar fashion to this a couple of days ago with another MOSFET. You would be better providing a link to the PDF datasheet as it is not enough to know just the voltage and current rating of the device. The wattage can be ignored for practical purposes in linear (class-b amp) use.
As I said last time, we need to see the safe operating area (SOA) graph. The input capacitance (Ciss) and gate charge (Qg) are also important parameters.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#5 |
...is too high for normal aluminum/air cooling. You'd need something very high end to cool these properly. Perhaps water cooling, probably with a copper block and high flow rate, maybe even refrigerated. In any case, not for the uninitiated...
just my 2c Stuart |
#6 |
Here is link to Data Sheet:
http://www.irf.com/product-info/data...irfp90n20d.pdf What driver stage could be used to drive this "monster" MOSFET. Any schematics? Thanks |
#7 |
Hi guys,
Take a look at this APT20M18BVR MOSFET SOA, which is "A REAL MONSTER ". regards, kanwar
#8 |
Hi guys,
The BIG DADDY of all DISCRETE semiconductors on the earth is this IGBT - APT100GF60LR, 600V- 100A device. Take a look at its SOA curve. we are using this in our project. regards, kanwar
#9 | |
You can very well use "INDIVIDUAL PUSH_PULL DRIVERS" for upper rail and lower rail mosfets to achieve excellent sink-source properties. using conventional driver schems is not worth, as they perform very poor in terms of turn-off time domain of mosfets. regards, kanwar
#10 |
Workhorse,
Can you post schematic with "good" drivers for these MOSFETs. Thanks, Zoran |
| Is this FET good to use into audio amplifiers? | destroyer X | Solid State | 18 | 14th February 2009 05:43 AM |
| Do coat hangers sound as good as Monster cables? | Geek | Everything Else | 14 | 7th March 2008 10:46 AM |
| WTB: IRFP90N20D | GERALDO | Swap Meet | 1 | 12th December 2006 08:49 PM |
| The good, the bad, and the ugly OTL amplifiers | Original Burnedfingers | Tubes / Valves | 46 | 9th November 2006 06:27 AM |
| schematics for amplifiers, found good site | NB23 | Car Audio | 0 | 12th June 2004 10:42 PM |
| Page generated in 0.11926 seconds (73.25% PHP - 26.75% MySQL) with 11 queries |
