Nelson/ others,
I read about your comments about the effect of reducing feedback, and I tried it in my Adcom 555. I loved the bass after the reduction, I increased the FB resistor (R123) from 22k to 30k. Issue is now I hear a little more noise and hum at the speakers (ears about 6 inches from the speakers). While not a biggie, I'd like to take care of it. Is there some standard calculation for feedback resistors and input impedance resistors (R102 and R103) whereby gain can be kept same as it was before reduction of NFB resister? Schematic attached for reference: please disregard the red highlights. thanks in advance! |
#2 |
I think you just increased the gain which is (22.1k/R124+1)
as this is just a giant non inverting op amp. Tom |
#3 |
I'm impressed with the adcom designer's trust in component tolerance;
the current balance in the diff pair is strongly influenced by Vbe and Vf differences of 3 different types of transistors and the bias diodes - even assuming the diff pair Qs match perfectly - toss in some R tol and possibly line V effects too for repeatable performance and low distortion the diff pair Qs must match and be biased within < 1 % current balance - without degeneration or trimming I don't see how this can be expected in production I would go for current mirrors for bias balance alone, but I would also welcome the extra loop gain if you want to "spend" some of the loop gain, degenerating the diff pair might be the best place to swap some global gain for linearizing local feedback - degeneration won't fix current imbalance but it gives you a good place to measure it and then you can trim the bias elsewhere (trim collector load R or VAS bias R) |
#4 | |
That be da Pass man! |
#5 |
JCX,
If I understood you, your solution would be to add a couple of resistors on the Tails (emitters or collectors) of Q101 and Q102 to reduce (and linearize) the gain as opposed to modifying the value of R124 to something like 1.35k? If so, approximately what values do you suggest? I am leery of playing with the input diff pair because of modifying the distorition spectrum, absolute value or even sonic qualities (or lack of) in the amp. Basically it wil cease to be a 555. (For bette or worse). K- |
#6 |
I'm not an advocate of reduced loop gain, but if that’s what you want to explore;
assuming d103,4 are Si diodes, tail current ~= 2 mA, 1 mA in each input diff pair Q gives 1/26 mho gm, adding 26 ohms in series with each of Q101,2 emitters reduces loop gain by 2x, 52 ohms by 3x, 78 ohm 4x, ... http://www.dself.dsl.pipex.com/ampins/dipa/dipa.htm discusses input pair distortion about 20% down the page adding the assumption that the VAS output sees a large resistance, ie not a shunt R, then you could try 50 and 100 ohm degeneration R in the input ~= 3x and 5x loop gain reductions carefully matching the emitter degeneration Rs to << 1% lets you measure the current balance by measuring the deltaV at the diff input emitters adjusting R105 collector load or one of (R112+113) or R116 lets you exactly balance diff Q currents - assuming they are well matched in Vbe, Hfe there is a small noise penalty for emitter degeneration but as long as emitter R < ~1/3 of the feedback network R or input series R it shouldn’t be noticeable hobbyist equipment may not be adequate to make sub mV measurements - if you have the resolution, averaging measurements with alternating lead polarity could remove some fixed offset digital multimeters may require a cap across their input and a series R to prevent digital sampling noise injection into the input Qs Vbe junctions causing offset from rectification - or at least series R >>10X the emitter R to keep meter input C from affecting amp stability |
#7 |
Hope I'm not too late for this discussion...
K-Amps, yeah, I read the feedback post too and had to double-think my education when the author of the post said 30-33k ohms. FWIW - I worked at the "factory" for Adcom Service, Technical Support & finally Product Development many years ago, and I currently modify/optimize Adcoms for fun & profit. Up until now my big secret was to match the input pairs. I do this with with a voltmeter with hfe measurement capability - this will essentially give you the gain of the DUT. What you need are a handfull of transistors (2SC2362 for 555II or 2SC2240GR for 555) and some time. Go through and measure all of the transistors and write the values down - once complete, select the four highest values with the closest matching numbers, i.e.; 677 & 676 for one channel and 650 & 650 for the other channel. Ideally, you should measure these values at operating temp, but room temp is ok as long as you don't hold the transistor (and warm it up). I really dig this forum - on the one hand, I'm overwhelmed by the technical competence here, on the other hand, there does seem to be a bit of misinformation as well. I just read that Adcom matched their output devices on the 5xx series - that's new to me! They never matched BJT devices, and they barely match the MOSFETS on the newer amps. FWIW - when I was in the service department, most of my co-workers replaced parts and nothing more - they did their job, met their quotas, and got a paycheck - I was one of the few poeple who worked there who actually cared about audio and could hear a diffefence....sheeh. Most Adcom 2ch amps are brilliant designs, but Adcom kept/keeps the price low by losing focus on the little details that add up to make a truly fantastic piece of gear. Oh and about feedback - if you want to change the "hue" of the Adcom "color" then try different types of resistors in the feedback path - the effect is rather dramatic. Good luck, -JamesW- |
#8 |
James,
Excellent post and very helpful thanks! Yes I have tried different values for R123 and the effect is rather dramatic. Very nice indeed. I will take your advice on matching the input diffs, seems like a very good idea knowing that they were not matched. I have had very good successes with weaking the 555's, excellent amp for the money. My fav Adcom is the 545ii, so natural. A power supply upgrade on that and man it sounds nice. The 5802 is just like my old Hafler Dh500, nice mids, nice bass but terrible highs. Actually they are so smeared that I cannot even call it hi-fi. I'd hate to call it a MOSFET characteristic but for now thats all I have.... K- |
#9 |
Do you have a way to identify the actual center frequency of the buzz/humm? That could give some of the readers more ideas on possible solutions.
When you wrote 33k being substituted for 20k my first thought was "Johnson noise, maybe?", but that would be more of a hiss, I think, than a buzz. If the the noise is centered around 100-120Hz, it is likeley related to the power rails some how. Since it arose after modifying the NFB it seems possible that is entering via the arm of the NFB net that connects to ground. Self comments on this and suggests increasing the cap on the lower arm of the NFB network, but I'm not sure how amenable the Addcom is to this. Maybe someone with a better understanding of the Adcom would care expand on this. |
#10 |
Sam,
Just plain old 60Hz hum. I think by reducing the FB factor and the resultant increase in gain, there is a slight increase of the noise floor and hum artifacts. It could be considered normal for some amps, like for example after modification, the hum is still less than a stock Adcom GFA-5802 (which is a MOSFET design and has very low feedback IIRC via a 100k resister.) How ever you "Johnson Noise" thoery is interesting... I guess I will have lug out Self's book from the basement, K- |
| Reduce "pop" noise when power on/off | veckans | Class D | 11 | 28th January 2009 09:53 AM |
| Reduce input noise | YUTK | Solid State | 18 | 27th December 2005 12:04 PM |
| Can I reduce digital ground plane noise? | fastcat95 | Digital Source | 7 | 12th May 2005 06:12 AM |
| How can I reduce mechanical turn on and turn off noise? | soundNERD | Chip Amps | 8 | 28th October 2003 01:43 AM |
| optocouplers to reduce digital noise? | dorkus | Digital Source | 9 | 23rd April 2002 05:41 AM |
| Page generated in 0.13077 seconds (79.83% PHP - 20.17% MySQL) with 11 queries |
