Account Disabled
in my project the capacitors always overheat and explode ( i us in 160V 68uF ) what can i do that the capacitors don't overheat and explode....????
the parts: R1,R2 = 10 ohm, 5 watt R3,R4 = 180 ohm, 1 watt C1,C2 = 68uF, 50 Volt (or higher volt) D1,D2 = 1N4002 Q1,Q2 = 2N3055 T1 = 220 / 24ct Transformer |
#2 |
The way i used to build these, C1 and C2 did not exist.
The base resistors were 1k and went to the collector of the other transistor. |
#3 |
Account Disabled
i dont incomprehensible your explanation on the inverter...
u can post a circuit or painting of this?? if is work thanks u!!!! |
#4 |
Delete R3, R4, C1, C2
Tie resistor 1K from base of Q1 to Collector of Q2 Tie resistor 1K from base of Q2 to Collector of Q1 |
#5 |
Account Disabled
like this??
and is work good???? is normal a 1K ohm resistor?? |
#6 |
I don't see how you get a 50/60 Hz sinewave out of this...
#7 |
Account Disabled
it is simple inverter....... is dont give 50/60 Hz ...
kevin gilmore u can answer me???? |
#8 |
You probably want to delete R1, R2, D1 and D2 too.
Its about 50/60 hz, and is definitely NOT a sine wave. Exact frequency depends on the transformer. Very similar to the heathkit inverters of years ago... What do you want to do with it??? With the transistors specified it is good for about 200 watts max. |
#9 |
Account Disabled
sooo the "FIX 2" work or not? or the "FIX 1" is better??
#10 |
Account Disabled
this is work well?? i need it for home AMPLIFIER to put in a car...
my amp need 280W and if i change the 2N3055 in 2N3771 is out more power? |
| Smps 220vac / 13.8vcc For 100a | albert_emule | Power Supplies | 13 | 14th July 2009 01:17 AM |
| 220VAC to 12VDC conversion | ioanno | Class D | 1 | 21st December 2004 12:24 PM |
| i have a problam.... i have a car amp and i want... | Dj BASS AMP | Solid State | 77 | 14th July 2004 02:57 AM |
| Transfrmer problam ! | Dj BASS AMP | Solid State | 21 | 2nd June 2003 08:04 AM |
| New Amplifier circuit - Problam | Dj BASS AMP | Solid State | 23 | 24th April 2003 10:26 PM |
