nouvelle electronique
Hello everybody!
I found this diagram in the last issue of "Nouvelle Electronique". It is a simple class a amplifier, 10 watt output power, 10Hz to 100KHz. All resistors are 1/4watt. Nothing to tweak.
I am not sure on the wrightness of the diagram: R5=R6=18K???.
C2=220uF but C1 1000uF????. can anybody tell me, is this correct???.
Can I use a double power supply +- 12V by conecting C3 at 0 volt???.
And in general it is a useable/good diagram?
Thanks !
WRONG again! T3 is a pnp too.
Excusez moi svp. THIS IS THE WRIGHT DRAWING.
Can I use a dual power supply by conecting C3 on 0 volt and eliminating C2??
Comparing with the JLH amp: the resistor on the Q2 colector (JLH) in a 7watt one.
Here (nouvelle electronique) the same resistor in the T4 emiter is a 1W ( 0.25 x 4). Why?
No , because that way , the offset will not be controlled...
Because in your schematic the dissipation in that resistor is ~ 0,6W..so 1W is enough .
Attention in your last schematic T1 is still up side down :att'n:
Yes;
Thank you. This is what I wanted, but I don't realise by myself if your schematic is right. Comparing with JLH 1996 (see bellow), it seems to be a simplified version. Why did you changed the T1 base polarisation (R5=R6 in the initial drawing)?
Somebody else comments?
eLarson:
Tip142 is a darlington transistor which has internal on-chip resitors ie 8k, but if we add smaller value we speed-up amp...
I think that standard Miller compensation is good enough (C4), 47p is initial value...
regards,wk.
for me current is too small...
R1=0.47R then I=0.7/0.47 =1.5A
1.5 x 24V = 36W per channel
