HI,
I need schematic for Power Amplifier with Op Amp on input( TL 071, NE5534...) and power around 150W. Not too complicated but reliable---PLEASE. For output I would use MJ15003/15004. Thanks...
#2 |
Did it Himself
Lynx amp.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 |
for 150w into 8 ohms you will need Vrail about 60v to 63v. This will require an output pair that can take 126v while drawing worst currents. MJ15003/4 prefer a slightly lower voltage. They will cope easily with a Vrail of 50v and optimised for highest power will just about manage 120w into 8r. If you really must have >60v rails the I recommend a higher voltage output pair.
regards Andrew T. |
#5 |
edl.atw.hu/pa300.djvu
you need a "djvu" reader to see it. the schema as a picture: http://www.audiofanatic.it/Schemi/Ti...5003_15004.jpg |
#6 |
the mj15003/04's Uce is 140V. so the max rail voltage is +/-70V.
with +/-70V rail an amp produces 190W-sinus to 8ohm. looking to the soa of the transis: at 70V Uce it can handle 2.3A at 190W on 8ohm the current is 2.44A. so you need to use 2 pairs. (because of the much heat, too!) for 150W-8ohm +/-63V rail is enough. if your heatsink is really-really big, you can use one pair. but don't do it! |
#7 |
AMP WILL WORK ON 4 OHMS !
Thanks. Please something simple. I had schematic of PA with TL071, TIP31/32 drivers, 2N3773 x 2 but I lost it. Thanks...
#8 |
What happened to your other amplifier ?
This one: http://www.diyaudio.com/forums/showt...862#post582862 Mike |
#9 |
That amplifier is DONE.
It is in a box already.Friend of mine was just asking me about some good,reliable and simple amplifier design using OP AMP on input stage ( he loves OP AMPS).He wants me to build it for him. I will post pictures of that first amp soon. Thanks for your interest an first amp. |
#10 | ||
hi maybe that amp was something like this: edl.atw.hu/ta_3600c.jpg this amp was sold as a kitset from China, as I heard. It's not a simple amp, anyway. Quote:
| HELP: BJT input op-amp's input bias current compensation | frickecello | Solid State | 6 | 19th June 2007 12:00 AM |
| Adding a third input to a differential input stage? | maudio | Solid State | 15 | 11th October 2006 02:16 AM |
| current bias j-fet input 2sk170 ,2sj74 at input stage | YUTK | Solid State | 11 | 2nd June 2005 03:34 AM |
| Resistor-Input vs. Choke-Input vs. Cap.Multip. | Blitz | Pass Labs | 13 | 26th September 2003 04:59 AM |
| Page generated in 0.11033 seconds (80.75% PHP - 19.25% MySQL) with 11 queries |
