Old 6th March 2005, 05:28 PM   #1
Milo is offline Milo  Italy
Milo's Avatar
Default Audio Active Filter
Hi all,
I have to make an active audio filter with the following specs:
- Low-pass < 200 Hz
- Band-pass: 200 Hz - 2.0 kHz
- High-pass: 2 kHz- 20 kHz
Which type do you suggest? I thought to make it with Bessel type.
Is UAF42 universal filter suitable and good in terms of noise for a quality audio application?
Any suggestion will be very appreciated.
Milo
Old 6th March 2005, 05:36 PM   #2
jcx is online now jcx  United States
http://www.linkwitzlab.com/filters.htm
Old 6th March 2005, 05:46 PM   #3
Bill Fitzpatrick's Avatar
That chip locks you into 2nd order which may or may not be suitable for the drivers you are going to be using. I assume you are tri-amping.
Old 6th March 2005, 06:20 PM   #4
Milo's Avatar
Hi Bill, Hi jcx,
thanks for your support.
Yes Bill, I am going to make a triamp. Any suggestion?
jcx, you moved me to a very professional website, excellent indeed, but I need, at the moment, a more practical circuit. The maximum should be: " Hi Milo , here is the circuit you need, it works very good and, if you need also the PCB, you can download here.....".
Of course I am asking a lot, but such approach could be wonderful.
Thanks again
Milo
Old 6th March 2005, 07:10 PM   #5
Did it Himself
richie00boy's Avatar
ESP site has articles and a project to suit your needs. Boards are also available at a good price.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 6th March 2005, 08:00 PM   #6
1543 is offline 1543  Germany
1543's Avatar
does anybody know these crossover-boards from BMM-electronics?
http://www.bmm-electronics.com/Produ...roduct_ID=2305
Arne
Old 7th March 2005, 12:54 AM   #7
djk is offline djk
djk's Avatar
The BMM is not designed properly for the mid output.
At first ESP made this same mistake, and has corrected it now.
Buy the boards from ESP.
Old 7th March 2005, 07:39 AM   #8
Did it Himself
Can you elaborate on what the problem is, I can't seem to spot it with a quick look at their site.
Old 7th March 2005, 08:02 AM   #9
MBK is offline MBK  Singapore
I was wondering about the L/R 3 - way connection issue as well:
- Siegfried Linkwitz himself in his Phoenix etc, connects all three bands, the HP for high, the BP for mid, and the LP for low, straight from the buffer and in parallel, as does BMM.
- But ESP connects the LP of the low section in series after the LP section of the mids. What gives??
Old 7th March 2005, 08:20 AM   #10
Milo's Avatar
Hi all, thanks all for your info. I had a look to ESP and BMM filters. ESP seem to be honestly made and with a good price. BMM seem to be excellent made, with excellent components.
About their behavior, I know nothing. I'd like to know, if possible, which of them could be the best. Please try to explain.
Thanks again
Milo
Active Filter Four help Cobra2 Solid State 9 21st April 2009 10:00 AM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
Audio Active Filter Milo Analogue Source 0 6th March 2005 04:08 PM
Active Filter - GvT GvTT Solid State 0 3rd February 2004 09:31 AM
looking for active filter sim P.Lacombe Everything Else 0 2nd January 2003 09:33 PM
Page generated in 0.12634 seconds (70.55% PHP - 29.45% MySQL) with 10 queries
