What do uncompensated amps behave? - Page 2 - diyAudio
Old 7th March 2005, 12:11 PM   #11
MikeB is offline MikeB  Germany
MikeB's Avatar
Default Re: What do uncompensated amps behave?
Originally posted by tmblack
My power amp does not oscillate but if sounds overly crisp and detailed
in a bad way.
I used a current mirror instead of resistors in a LTP.
What tests can be applied to test the compensation of an amp?
Tom
Hi Tom !
You ran into some typical trap. You increased openloopgain to
lower thd, but at the same time you reduced openloopbandwidth...
This results typically in exactly this sound you described.
You can remove this by adding a resistorload to the vas, try a 22k
to ground. Check your amp that it has openloopbandwidth flat
up to ~20khz.
Don't forget, low THD only means low distortion on sinus-signals.
Often low THD results in high distortions for complex signals
like music. But an amp is intended for music...
This crisp sound is normally heavy intermodulationdistortion,
it's not caused by instability.
Mike
Old 7th March 2005, 02:52 PM   #12
traderbam's Avatar
Inevitably, someone will pop up at this point and start screaming about how it lowers distortion, etc.
No one seams to have popped up so I thought I would. NFB does lower distortion, etc.
Your proper response to such a post is to ask them how often they listen to live, unamplified music. Amplified music doesn't count--it has to be unamplified, elseways you're listening to the PA system, and PAs make lousy stereos.
Quite often down my local Jazz pub.
Just to apply some balance here:
If you really understand what you are doing...
a) Feedback is extremely good - as much as possible.
b) Bandwidth beyond the audible range is unecessary
c) Miller compensation is just fine, better than many methods.
I'm not trying to be controversial but rather I wouldn't want budding designers to adopt assumptions that limit the potential of their designs.
Old 7th March 2005, 02:57 PM   #13
MikeB's Avatar
As much as POSSIBLE, not as much as DOABLE !
Mike
Old 7th March 2005, 04:31 PM   #14
tmblack is offline tmblack  United Kingdom
Hi MikeB,
I like to test your theory, so how can I measure the IM with my computer and soundcard?
Is there any free program?
Tom
Old 7th March 2005, 05:11 PM   #15
MikeB's Avatar
Hi Tom !
There are programs for this, but i don't know jack...
Maybe someone else can tell ?
I'm not sure if this kind of problem shows up in normal IM-tests,
i tried to reproduce this problem in sims, but with the normal
2freqs-im test it did not show up.
But you could try adding such a resistor in the vas, if it's this
OLBW-problem, the sound chould change immediately.
Mike
Old 7th March 2005, 07:27 PM   #16
jan.didden's Avatar
Default Re: Re: What do uncompensated amps behave?
Originally posted by MikeB
Hi Tom !
[snip]Mike
Mike,
This is misleading. The open loop bandwidth is reduced, but only because the gain at frequencies below the original cross-over frequency is increased. The gain above the original cross-over frequency is unchanged. So overall, there is more gain available between DC and the original cross-over frequency.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 12 is out! Check out my Autoranger and SilentSwitcher
Old 7th March 2005, 09:32 PM   #17
MikeB's Avatar
Hi Jan !
Yes, you're right, my point was more like openloopfrequencyresponse
has to be flat within audioband... I don't know why...
But in every single amp i've constructed it was absolutely necessary
to keep it flat, or sound was "trash".
Mike
Old 8th March 2005, 02:57 AM   #18
I am thinking current mirrors as active loads sound bad.
My LM3886 chip amp sounds extremely harsh.
Tom
Old 8th March 2005, 03:19 AM   #19
anatech is offline anatech  Canada
anatech's Avatar
Hi Tom,
Not neccessarily. Current sources help isolate the signal from supply noise and make the circuit more stable if designed properly. Degeneration helps linearise the circuit and burn off extra gain so the amount of feedback can be reduced. Too much feedback absolutely sounds bad.
Besides, I really like all the lights from my LED biased current sources.
-Chris
Old 8th March 2005, 06:19 AM   #20
Warp Engineer
On Holiday
AudioFreak's Avatar
Well if you want decent phase response anywhere near the edges of the audible range then it's pretty much manditory.
- Dan
How do opamps behave open loop? leadbelly Solid State 6 11th August 2009 06:07 PM
Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest mbcouple Swap Meet 2 27th October 2008 11:27 PM
do ucd modules behave like snkby Class D 13 12th April 2006 04:40 PM
My new amp have a strange behave help! Progg70 Analog Line Level 5 17th October 2005 07:54 PM
oups! linear regulators of the same type may behave pretty different noisewise! Dominique Power Supplies 5 30th April 2005 02:34 PM
Copyright ©1999-2017 diyAudio
