What do uncompensated amps behave?
Old 8th March 2005, 07:34 AM   #21
Hi Dan
what is mandatory?
An open loop bandwidth wider than audio?
Or open loop bandwidth beyond the audible range is unecessary?
If beyond then how far beyond?
regards Andrew T.
Old 8th March 2005, 08:49 AM   #22
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
Well ideally you should have closed loop FR an order of magnitude outside of the band you intend on using. So if you want 20Hz - 20kHz, you should be thinking something around 2Hz - 200kHz.
- Dan
Old 8th March 2005, 10:12 AM   #23
MikeB is offline MikeB  Germany
MikeB's Avatar
Hi Tom !
Have you tried the resistorload in vas ? It's a very simple change,
just add a resistor in vas to gnd, or symetrical, two, one on each
side of vbe-multiplier.
Mike
Old 8th March 2005, 10:21 AM   #24
MikeB's Avatar
Originally posted by AudioFreak
Well if you want decent phase response anywhere near the edges of the audible range then it's pretty much manditory.
My experience is, phasehifts within closedloop are evil, the less
phaseshift the better dynamics and details. Sadly i was not able
to get below 20° at 10khz with the amp beeing stable.
(the 20° with opened loop,phasedifference from input to output)
But, with "normal" designs, you easily reach values above 50°.
(like ccs-loaded vas, driven from currentmirrored LTP)
Do you mean -3db at 200khz ?
Mike
Old 8th March 2005, 12:35 PM   #25
traderbam is offline traderbam  Europe
traderbam's Avatar
But in every single amp i've constructed it was absolutely necessary to keep it flat, or sound was "trash".
There are two possibilities: either having flat open loop phase within the audio band is important, or the thing you changed to achieve this changed the sound for an entirely different reason.
Ideally there should be no distortion whatsoever. In practice the O.L. bandwidth is not very important of itself. If you are using feedback then you want as much as possible: typical designs use Miller compensation to create a first pole at only a few hundred Hz, causing the O.L. phase to drop to near 90 deg during most of the audio band. But this doesn't really matter. I'd say you want to aim for a C.L. bandwidth of 40kHz and any more isn't important. What can happen is that when a designer alters the circuit to create a 200kHz bandwidth they also alter other factors and it is these other factors that dominate the sound.
Old 8th March 2005, 01:18 PM   #26
MikeB's Avatar
Yes, i was thinking about that too, adding these resistors lowers
Z-out of the vas, making it less sensitive to reactive loads.
But my latest amp did not need these resistors for reasonable flat
OLBW, and it sounds as it should, like the others with resistors.
Mike
Old 8th March 2005, 09:31 PM   #27
Warp Engineer
On Holiday
AudioFreak's Avatar
Yes. Although commercially -3dB at 100kHz is more practical there are a few situations where you can really benefit from -3dB @ 200kHz if you pay close attention to stability etc.
- Dan
Old 9th March 2005, 02:41 AM   #28
thanh is offline thanh  Viet Nam
thanh's Avatar
Send a message via Yahoo to thanh
My LM3886 chip amp sounds extremely harsh
Have you ever listened the sound of TDA7295?
Justice for Victims of Agent Orange
http://www.petitiononline.com/AOVN/Thank all of you!
Old 9th March 2005, 05:15 AM   #29
tmblack is offline tmblack  United Kingdom
I haven't tried the TDA7295.
Is that a smooth sounding one?
The current mirror seems to make the sound unnaturally crystallized.
Could this be the transistors used(2SA1015)?
Using resistor loads in LTP and current source sounds very natural.
Tom
Old 9th March 2005, 12:06 PM   #30
MikeB's Avatar
Hi Tom !
Can you show schematic of your amp ?
Mike
What do uncompensated amps behave?Hide this!Advertise here!
How do opamps behave open loop? leadbelly Solid State 6 11th August 2009 06:07 PM
Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest mbcouple Swap Meet 2 27th October 2008 11:27 PM
do ucd modules behave like snkby Class D 13 12th April 2006 04:40 PM
My new amp have a strange behave help! Progg70 Analog Line Level 5 17th October 2005 07:54 PM
oups! linear regulators of the same type may behave pretty different noisewise! Dominique Power Supplies 5 30th April 2005 02:34 PM
Copyright ©1999-2017 diyAudio
