I have a ML38 preamp board I acquired a while back without chassis. It has been working well and sounded great until 2 weeks ago when it started generating loud humming sound. I checked the output DC offset and both channels are below 0.5mV. I also checked the voltage on each opamp and all seem to run at spec'd of +/- 14.89V. The preamp is functioning as normal. The weird part is when only 1 output channel is connected, either right or left, there's no hum. But only when both output channels are connected, loud humming occurs. I used XLR for inputs and RCA for output. The rectifiers (MUR860s), capacitors and regulators were replaced about 2 months ago. Help, what can be wrong? (or maybe it's complaining to me it's time to get the preamp a new chassis)
thanks, |
#2 |
Sounds like a ground loop through the input RCA grounds. Try a 10R resistor in each RCA jack ground, or find out what changed (possibly broke off).
-Chris |
| Humming | Jorgitox | Solid State | 19 | 29th November 2007 02:42 PM |
| Humming Zen V4 | Diomedian | Pass Labs | 4 | 26th April 2006 08:30 AM |
| Why is my snake humming? | Pbassred | Everything Else | 12 | 6th January 2005 10:05 AM |
| Humming GC | fireman | Chip Amps | 9 | 8th August 2004 06:44 PM |
| humming amp | Pumuckel | Pass Labs | 10 | 26th February 2004 12:40 AM |
| Page generated in 0.07343 seconds (67.02% PHP - 32.98% MySQL) with 10 queries |
