simplest amplifier possible with BJT's?
Old 15th January 2003, 12:01 AM   #21
halojoy is offline halojoy  Sweden
On Hiatus
Originally posted by PMA
This one will be workable and will give reasonable output o several watts....
You should put input output at about 60-65% of V+
in this type of circuits.
For better Effiency.
Negative swing can NOT be more than 15/2= 7.5 volt
Positive swing will need to be 7.5 volt,
Leaves 7.5 volt over Transistor.
If we set output at 60%= 18 volt
gives 9 volt negative swing (8 ohm resistor & 8 ohm load in series)
Leaves 3 volt over transistor
at +-9 Volt output.
All these calculations based on 30V DC supply.
30v/1.875A - In this case 7.5Vp= 3.51 Wrms/56.25= 6.24% eff
30v/2.250A - In this case 9.0Vp= 5.06 Wrms/67.50= 7.50% effiency
/halo - good at simple math - not necessary good amp designer
Old 15th January 2003, 09:07 AM   #22
rmgvs is offline rmgvs  Netherlands
Default additional schematics
In order to make this sample of circuits complete, here two extra circuits. They were designed/suggested to me by Geoff Moss in a discussion on these circuits (starting with the AR-3 headphone amplifier but built for normal speakers).
I have actually built these circuits and compared them with the original, but modified for 8 Ohms, AR3. These two circuits gave around 2 Watts RMS into 8 Ohms (the AR3 around 0,5 W under the same circumstances).
Strange enough, both these circuits did not fullfill my expectations on grounds of sound quality alone. I built all circuits using the same components (brands, types etc). They were good, but in the same league as the John Linsley Hood or Hiraga (and then I would suggest to build one of these). The AR3 however improves upon all of them (of course, subjective, but alas).
(pictures do not show in preview of supply!)
Old 15th January 2003, 09:13 AM   #23
Default the other circuit
here it is
Old 19th January 2003, 07:50 PM   #24
Neutron Bob is offline Neutron Bob  United States
Neutron Bob's Avatar
Send a message via Yahoo to Neutron Bob
Default Darlington Output?
Interesting to see a simple amplifier using Darlingtons. Years ago (about 15), I liked them because of their incredible gain and simplicity: I didn't need a driver transistor to saturate them.
Of interest: I was using them as switches for motorcycle headlight modulators. I liked being able to connect directly from a CMOS timing circuit directly to the output stage. Space was of the essence in a little potted package.
The burning question is this: how are they in an audio application? Sufficiently quiet and linear?
I'm all ears...
Bob
Old 19th January 2003, 09:47 PM   #25
On Hiatus
Arrow about Darlingtons & ME, halojoy
I tend to never use true darlington configuration.
If I need so much gain, I nearly almost use compl foldback, CFB.
And If I use one to drive another,
I do not connect the collector of the first one
to the second one's collector.
But instead I let the first transistor use
as much voltage C-E as possible, make use of all the voltage of the power supply.
And I never buy Darlingtons that are Ready made.
They mostly have resistors incorporated already,
and mostly the base of the output transistor
has no pin.
/halo
Old 30th January 2003, 07:38 PM   #26
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Hmmm
I'm suprised nobody got the idea....to use.....
IRON!!!!!!!
Used all the time in toobz, it allows all the power from the output to flow into the *speaker* and not be shared with a resistor.
100mH should be all that's needed for good LF, and one could even put a resistor in series for a softer bandwidth rolloff.
Check out my thread "Far be it for ... SS" for the last thing I breadboarded. Guess I'm now obliged to wind a 2A 100mH choke though..
Tim
Old 30th January 2003, 11:35 PM   #27
traderbam is online now traderbam  Europe
traderbam's Avatar
I think iron went out of fashion at the end of the last century. Now it has been replaced by steel and aluminium. In any case, I'd think the purist would be better off investing in an aluminium heatsink to make a 2A CCS rather than winding copper around an anvil. Having said that Ciclotron has made an SE output amp using a big inductor; and I think this Vernesque machine suits his enthusiasm for "Metropolis" style.
On the topic of simple circuits I would like to introduce the idea of simplicity of concept rather than "as few transistors as possible". I think if you use too few devices their distortions can total more than using more devices in a more linear way. If I were trying to make a great sounding amp, without global feedback, I think I would simply use a cascade of common-emitter BJT stages, each with emitter degeneration to linearise each stage and to give each stage a current gain <1/10 that of the transistor. Have as many stages as needed until the final stage drives a 1-ohm resistor. Place the speaker across the 1-ohm resistor. It'll get hot. But no-one said it couldn't get hot. And never reference any voltages off the power rails - they are polluted.
The primary reason to use emitter-followers, or darlingtons to buffer the output is to reduce heat. With a 1-ohm output resistor a +/- 12V swing will burn 72W avg. With a CE buffer (say with a beta of 100) you can use a 100-ohm resistor and burn about 10W avg. But CE followers are not so linear and can be somewhat reactive and in some cases unstable.
Old 31st January 2003, 04:36 PM   #28
sser2 is offline sser2  United States
Attempts to increase power without increasing distortion in that good-sounding 50 mW headphone amp (RudiStor AR3) are doomed and you don't have to do any tweaking to come to that conclusion. The first and the least important reason is power dissipation. The original version puts out 50 mW consuming 3 watts of power, that is about 1.7% efficiency. If you scale up everything to get 5W, the power consumption will be 300W. Indeed, as we learned, increasing output to .75W increased power consumption to over 30W. Even if you are not frustrated with an idea of building such a wasteful amp, there is a second reason why you cannot do it. This more powerful version will require more voltage swing from the first stage, which you cannot implement without sacrificing distortion figure, because of bad effects of Miller capacitance. So, no magic here, we are inevitably facing the problems we know all too well in matcing good performance and high power.
Old 3rd January 2004, 12:19 PM   #29
Default this can be it!
This thread in the solid state forum has been dead for quite a while now. Just recently there has been a publication on the net that may contain the amp am was searching for all the time:
http://www.redcircuits.com/Page80.htm
It seems to fullfill all of the design criteria I put in the first post. I will build this thing in due time but not in the very short run. I hope to meet other people in this forum who are open to experimentation and want to build this thing and are able to compare it to other good amps such as Zen, Hiraga, JLH etc.
Rudy
Old 3rd January 2004, 12:39 PM   #30
millwood is offline millwood  United States
Account Disabled
Default Re: this can be it!
Rudy
really? does it have a global feedback loop?
what about just a simple SE amp using a darlinton and active loading?
simplest amplifier possible with BJT's?Hide this!Advertise here!
ISO &quot;Simplest&quot; possible amplifier dano12 Solid State 32 27th February 2009 11:07 PM
LM3886 GC - &quot;Simplest Ever Amplifier Bridging&quot; jweber Chip Amps 20 18th June 2006 03:55 AM
simplest sub amp odysseybmx414 Solid State 2 28th December 2005 05:24 AM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 03:55 PM
