Hi all,
I live in Italy (220V/50Hz) and I've recently bought a 2nd hand Proceed CDD from a kind guy in USA. The unit is said "internally recognizing" both main tension and frequency, and is actually configured for 120V/60Hz. Now, as usually happens for PSU of items sold to different countries I thought of locating some tranny wire schema. I opened my CDD and found a sort of plug array where 2 brass-colored "U"-shaped jumpers were connected. They do short 2 pairs of connections. I guess that it might be possibile to reconfigure the jumpers to let them work with 220V. Would anybody you be so kind to suugest me a way to find the correct jumper configuration? Should this be too boring for you, I want to thank you a lot anyway. Ciao, Stefano |
#2 |
Ciao Stefano!
If the unit says it is self-recognizing, well... why don't you try to fire it up? Is it a smps power supply? if it does, it should be auto-ranging... |
#3 |
Ciao,
if SMPS means Switched Mode, no, it is not. We have a nice tranny (i guess a thoroidal one) in a black plastic container. as far as I remember, it's marked with usual 2 120v primaries, so you can configure it to work with up to 240v in input. Aside from jumper setup, I couldn't yet locate (and remove, of course) the frequency checking chip mentioned on the operating manual... Should you have any hint to "guess" the jumper config... TIA Stefano |
#4 |
Well, most of the times the 2*120V primaries are just a centertapped one, and it should be easy to convert it. The problem is to locate the wires: first you have to identify the primary wires. If you have a DMM with that funny continuity test use it with the mains plug of the supply, and check with what jumpers you have continuity. Now that you have identified them, if it is a centertapped transformer probably they will be two of the same colour and one of another. The pairs are your ones, connect them across the mains plug. If it isn't centertapped, well, you have to connect them in series.
But remember: if you have any doubts on doing electrical things, the only doubt you have means that you aren't sure of what are you doing, and please don't do it. Mains voltage is SO dangerous! I suggest to refer to a local TV guy... they are experienced enought in doing those things. Don't work with mains please! è un consiglio... |
#5 |
suggestion are welcome and attention is payed. Sadly by removing top cover, I couldn't yet locate wires to the tranny. So, I can easily access only this sort of jumper linear array. I thought of identifying jumper positions by measuring input impedance. Does this make sense? Second, where does common sense suggest frequency check chip to be located? Stefano |
#6 | |
More often than not, if you have 4 primary terminals in a row, it will wind up being something like this:
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#7 |
Thanks leadbelly,
I've an array/socket with 8 slots, and 2 "U" shaped and brass colored "jumpers" which connects 2 pairs of slots. The wires from the tranny goes to this white plastic multisocket underside the mainboard and couldn't yet locate them. Another issue is the chip which is said to store the "REF FREQUENCY" and matches this stored value with the actual mains frequency, in order to light the unit only if they match... mumble, mumble... Stefano |
#8 | |
#9 |
Sadly I got some feedback that this practice is also used by Krell, ML, in order to "close" markets...
BS!!! But, as components are there and we have a classic PSU (the tranny, 2 rectifier bridges, caps...)... so I'm wondering where, following logic, might this damned chip play a role???Stefano |
#10 |
Stefano,
I have the same problem as you had. I have Proceed CDD with 120V/60Hz set and i am trying to connect it to 230V/50Hz. Do you know how to make that works ? Thanks |
| LED on mains voltage? | AndrewT | Parts | 32 | 21st June 2011 09:04 AM |
| Digital zero-voltage SPS with PID contrlol and feed forward | Michael_V | Power Supplies | 0 | 26th September 2007 10:36 AM |
| Taming mains voltage | cbutterworth | Power Supplies | 2 | 16th September 2007 03:50 PM |
| 2nd Hand Technics Sl1210mk2 Voltage Problem | renegadezion | Analogue Source | 2 | 29th August 2007 04:38 PM |
| Carver AV-405/AV-505 mains voltage | rt_jensen | Solid State | 0 | 25th April 2005 03:03 AM |
| Page generated in 0.13190 seconds (75.46% PHP - 24.54% MySQL) with 11 queries |
