Old 28th February 2005, 02:11 PM   #1
Dave S is offline Dave S  United Kingdom
Default Leach Low-Tim Amp Finished
I finished my Leach amp about a month ago. It is currently my favourite SS amp out of the 5 DIY power amps I have, it is probably the closest one to the fabled "straight wire with gain".
Old 28th February 2005, 02:14 PM   #2
PCB:
Old 28th February 2005, 03:22 PM   #3
larryg is offline larryg  United States
larryg's Avatar
looks great!
larryg
Old 28th February 2005, 07:33 PM   #4
Thanks Larryg,
It actually looks better in real life. The pictures made me realise how difficult it is to make things that looks really good - like Peter Daniel does for example.
Anyway I'm very pleased with it, despite the complex wiring it worked straight off. It has no audiophool components in it and it sounds better than all my other SS amps (different to rather than better that my fully Mullarded Leak ST20).
Makes me wonder what all the fuss is about with SE class A, black gates, fancy wires etc etc.
Dave
Old 28th February 2005, 09:32 PM   #5
Mikett is offline Mikett  Canada
Nice work. One possible improvement is to cut the angle brackets in half and mount the other half closer to the board. You want the wires of equal length and shorter is better.
Old 1st March 2005, 07:07 AM   #6
Thanks - yes I thought long and hard about this. I would need to start again with the angle brackets and there is also an issue with the thermal compensation diodes. It would need one NPN/PNP pair per angle bracket otherwise thermal runaway may result. As it is, the wires are similar lengths because of the way they are routed. The square wave response into a 2.2uF load are reasonably well damped so the amp has a decent phase margin - I think this is the most important thing and hopefully this means the 6 ins long wires are not an issue.
I can see why people are re-laying the pcb for TO247s!!
Dave
My Leach Amp Clone (LEACH 150) panson_hk Solid State 28 15th August 2011 08:12 PM
High Current Leach/leach super amp bowdown Solid State 41 2nd March 2011 02:15 PM
Leach Superamp vs Leach 4.5 Samuel Jayaraj Solid State 4 26th October 2002 09:20 AM
Leach amp vs super Leach amp supernet Solid State 0 21st February 2002 10:16 PM
pics of my leach amp - just finished BrianGT Solid State 35 11th February 2002 06:50 AM
Page generated in 0.08484 seconds (72.61% PHP - 27.39% MySQL) with 11 queries
