#11 |
IC3 is an LF353N, 249A, which i think is the opamp? causing the problem
#12 |
Alps pot channel difference can be up to a decibel or more.
The LF353n is a dual opamp, pin compatible with a NE5532. If the opamp is broken you might consider swapping for a better one, the LF353n is rather cheap.
Not so much,.......if it says "ZM" in the corner. |
#13 |
would i need to change anything else other than the chip?
are there any differences between the manufacturer of the chips? so i could do a straight swap for an ne5532.. is it best to use a solder sucker when removing chips? i can see myself getting into a mess trying to get all 8 pins hot at once!! or should i just cut the old one out, get rid of the cut pins and then re-drill to get rid of any solder left in the holes? |
#14 |
I use a roll of stranded copper wire for removing solder, 50p
Put the end on the pin, place the soldering point on it, the solder flows into the copper strands, voila. Simple mechanical solder suckers dont work, imho. The NE5532 is a straight swap-in, it is the most used opamp for pre-amplifiers. Even used for the front end of quite a bunch of power amplifiers. There are different manufacturers, you can cross reference the datasheets at www.alldatasheet.com The 5532 has a bandwidth of 10 MHz, more than twice of the LF353, slewrate is a bit lower. An NE5532 can be had nowadays for 50p. Analogue Devices also has a number of excellent dual opamps. Above that is something like the OP227, a dual OP27 opamp. The best are Burr Brown models, the opamps have BB stamped on them. And Linear Technology has LT models. I would settle for the NE5532 in your preamplifier, the 5532 has been used in 1500 PS preamps. Go higher and you will probably be rebuilding the entire amplifier.
#15 |
right then, i think i am set.
i reckon there should be stars available to award people for helpful posts! i will get on with the ordering of the part, have a go at fitting them and be back here with smileee faces if it works! |
| Musical Fidelity B1 amp - repair and small mod | tuck1s | Solid State | 1 | 8th January 2013 08:57 AM |
| Musical Fidelity A3.24 repair | ronenash | Digital Source | 54 | 10th September 2009 09:02 AM |
| Musical Fidelity A5 | sakis | Solid State | 4 | 17th October 2008 02:00 PM |
| musical fidelity B1 | mcberta2 | Solid State | 0 | 31st December 2007 10:31 AM |
| Musical Fidelity CD Pre 24 | devron12 | Solid State | 5 | 7th January 2006 06:01 PM |
