#1531 | |
So is this using mosfets on the output, Ive never heard of this configuration on a leach.
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert |
#1532 |
yes and power stage as well would be nice to hear about.
#1533 |
Hi all,
Sorry for the confusion but the mosfets etc to the left of the Leach are for my other (some may say dark side) of my hobby. Parts and boards for ZEN9 amp and symetrical supply B1 pre-amp. I was just trying to show off the fact that I have some Power J-Fet LU1014 as I believe they are somewhat hard to come by!! So if you all are thinking that I am even close to the level of expertise that you good people are you are sadly mistaken. I am I true believer in if it aint broken (or works perfectly well) why try and re invent the wheel. So the Leach will be as per plans accept for the regulated front end. Thankyou all for the nice comments though. I would be more happy to answer any questions with regards to the amp etc. I'll keep you all updated. Ian |
#1534 |
...truth seeker...
bump for the current Leach clone build
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#1535 |
I am just getting around to the Small Leach build from 5 years ago and need some advice to proceed further. The pcb is stuffed except for the output transistors. Bob Ellis and AndrewT have helped with building a regulated power supply. Now the project is to the point of connecting the pieces together for testing, but before that occurs, some advice is needed for the enclosure. I am a woodworker so I was leaning towards a wood enclosure.
The heatsinks were obtained from ApexJr a few years ago--a pair of sinks 2.3 x 4.6 x 12.5 inches which can form a tunnel 4.6 x 4.6 as shown in the photos below. The mounting plane of the sink is 4.5mm or .175 inches thick. I have no idea of the exact cooling capacity of the sinks or even if an estimate of their cooling capacity is possible. The enclosure, if built with the tunnel, would be too high at 12.5 inches. Would anyone hazard an opinion if the sinks would be adequate to cool the unit if they were to be cut down to about 8.5 inches. The tunnel would be oriented vertically. A muffin fan is available in the tunnel size if 12 VDC can be obtained to feed it to help augment the heatsink cooling. But whether a fan is advisable or not is another question. The output transistors positionally mount on top of the heavier and deeper fins of the sink. If you see any obvious problems with the pcb feel free to comment as well.
Signature |
#1536 |
Another project for you - find a temperature sensitive fan controller circuit. Rod elliot has one and there are a few here, including a two speed controller. Mount the sinks horizontally and have a fan kick on only if they get too warm. Burying the fan inside a wooden case will help keep it quieter, although it probably would be slightly more efficient sucking air through the sinks.
I have four channels of Leach amp (V4.5 on Leach boards) on those sinks mounted horizontally running at ~100 mA bias each for 45W. The amp gets warm but not hot in normal use. Although I haven't really driven it hard I hadn't connected without a fan until recently. I'm using a 10W 120VAC fan - I don't remember its flow rating, but I cranked the bias up to 750 mA/channel (~330W) and the output end of the sink gets to about 50C (after an hour I can put my fingers on it for more than 10 seconds, but it is hot). The amp is doing double duty, making music and giving my bhut jalokia and other hot pepper seedlings nice warm days in my indoor hot house. Another month or so I'll turn the bias back down when it warms up enough to move the plants outside. |
#1537 |
The challenge would be to balance the size of heatsink with optimal bias vs temperature. With the thermal compensation diode feeding a fan controller circuit from ESP site that could make this automatic is definitely worth the look. This would be used to control fan speed.
Pinoy ikaw ay pinoy... ipakita sa mundo... kung ano ang kaya mo... |
#1538 |
Vertical sink tunnels are best. They need the least power assistance to achieve a certain cooling ability.
Blowing the sink is more efficient than sucking. Blowing also exposes the fan motor to cooler temperature. An early Pass had blown vertical sinks. Was it the *40? Three temp switches on the sink would be great. all off = fan off. first on = slow fan. Second on = fast(er) fan. Third = power down. or use a variable as Bob suggests, but still fit a power down switch, or at least a loud/bright alarm. BTW, the emitter resistor value and the PSU voltage determine the amplifier Pq. Watch for blowing fuses with those on board capacitors. 4700uF and +-58Vdc needs a long current duration to charge up. There is space for 15mF, but that is virtually un-fuse-able. Last edited by AndrewT; 28th March 2011 at 09:47 AM. |
#1539 |
That Pass amp was the A75.
I was thinking a multi speed fan, too. Seems easier to design/build a controller to me. Good idea for a cool down after shut down. The Hafler DH500 uses an AC fan and a couple of 300R/7W resistors in series. As temperature rises thermal switches sequentially close, increasing the fan speed. With 600R in series, the fan is virtually silent. You could add a lower temperature switch to shut off the fan completely at lower temperatures. Not the most efficient way to reduce the speed of an induction motor, but it does the job. |
#1540 |
Thanks for all the help guys. I have my homework. I'll have a look at the ESP solution. The consensus as I see it, do not cut the heatsinks shorter.
The heatsink tunnel is more efficient vertically but fan-driven horizontal orientation is just fine especiallyif Bob can run 4 channels off these sinks instead of the 2 that I`m using. I don`t have a greenhouse to heat either. Andrew, the emitter resistors are 0.47., the transformer is 39.8-0-39.8 so it should be about 56V at the PSU.
Signature |
