#11 |
The one and only
From experience, I can tell you that you get the most
PSRR for the buck with very careful attention to the quality of constant current sources that you might employ, particularly in creating voltage references for them. |
#12 |
Nelson,
Thank you for that pointer, something I shall pay some extra attention to in the design. I'm looking forward to this actually should an interestign challenge. regards, Andy. |
#13 |
Hi all
Could one simulate the PSSR in an amp by using a sine generator in series vith each of the rails amd the do a FFT on the output ? Is P - Spice' FFT any good ? \Jens |
#14 |
sorry
PSRR |
#15 |
Jens,
PSRR can most definitely be simulated in SPICE - it's easy to add modulation to a DC source and see the result. This is, in fact, what I'm currently doing in the design phase. It's easier than actually measuring it - you require some serious amp performance to swing AC over a wide bandwidth into lots of capacitance and maintain stability. A. |
#16 | |
Account Disabled
stick AC source in series with +DC supply, aC ground input, and run aC analysis.....repeat for -DC rail.... |
#17 |
ALW,
Have you try cascode topology in CCS? It can improve the output impedance and frequency response a lot... Wenyeh |
#18 |
Using a seperate rectifier and capacitors for the low current
stages and only using the main capacitors for the output stage. sreten.
#19 |
Electrons are yellow and more is better!
ALW started this thread in 2002 so the whole issue may be irrelevant for him....
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#20 | |
Account Disabled
Good idea! |
| PSRR of CF w/ CCS Sink | regal | Tubes / Valves | 7 | 30th June 2008 03:13 PM |
| Opamp PSRR | lumanauw | Solid State | 10 | 12th March 2007 12:42 PM |
| Class D amp and the PSRR | rtarbell | Class D | 14 | 12th January 2006 08:45 AM |
| PSRR and Crosstalk | dgardner | Solid State | 4 | 20th June 2005 01:09 PM |
| topology and PSRR | theChris | Tubes / Valves | 1 | 23rd August 2003 12:36 AM |
