Old 11th November 2002, 12:20 PM   #21
halojoy is offline halojoy  Sweden
On Hiatus
Them diode is a safety. To protect the Capacitor.
A capacitor destroys of too high voltage
or some volts negative.
Diodes make voltage never can go more than +-2 volt.
Normally diodes is not working.
If you use bipolar cap or Polypropylen, than there is no need, I think.
Old 11th November 2002, 02:29 PM   #22
Electrons are yellow and more is better!
peranders's Avatar
Default Re: Re: Re: THE M250
Originally posted by Drafance007
NO No What about naow 4 diodes 1n4148, what is their purpose ? ( D1-D4 ?
halojoy is right, the LED acts as a low voltage zener, 1.7-1.9 volts. (The no no thing).
/Per-Anders (my first name) or P-A as my friends call me
Old 11th November 2002, 10:32 PM   #23
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Default Base resistor
Originally posted by halojoy
The resistor 15 ohm is used, when the current limiting transistors, T6/T7 gets active, to limit the current flow through the transistors.
Well, I thought that it destroys the Q (In a possible LC cuircuit) , making the thing not oscilate.
\Jens
Old 11th November 2002, 10:41 PM   #24
On Hiatus
Default Drafrance007
\Jens
This is the correct answer Drafrance007.
Jens Rasmussen knows this. He have studied these things.
He should know.
But to more mortal souls, like me and Drafrance007
the answer could be flying some bit over our heads.
A good teacher speaks same language as his pupils.
doesn't he?
Old 12th November 2002, 08:51 PM   #25
Account Disabled
Default Re: Drafrance007
He should know.
doesn't he?
O.K.I Can.t say i comlete understand this but it it's purpose was bothering me. One intresting stuf...why so many out transistors...i...polled out 200w with 4 transistors bd911/912, maybe 6...mje...OK...but WHY 8 transistors... ???
Old 13th November 2002, 11:29 AM   #26
Hello again,
I see that some questions have appeared here,
and thay have already been answered by others!
Thanks for your interest!
Regarding the 8 output devices: yes, this number
may seem exaggerated. The amp will probably work
well with 6 or even 4 transistors, especially
for an 8 ohm speaker.
My intention when using 8 transistors
was to make the amplifier rugged. The maximum
power that the transistors can handle decreases
with increasing temperature. The 8 transistor
configuration is intended to allow for safe operation also when the amp is run hot.
Also, paralleling many output devices reduces
the effect of 'beta-droop' as described
e.g in Douglas Self's book.
Best wishes to all of you!
Marcus
Old 14th November 2002, 12:05 AM   #27
Account Disabled
Now, Just one more question.....if you pull-out the short-circuit protection....could the amp give twice as much power on a 2 OHM load....wit a beter power supply ???
Old 14th November 2002, 12:20 AM   #28
On Hiatus
why would you need twice as much
if there is already much
Are you gready (want more and more and more, never satisfied)
or are you an
poweroholic (an power addict)
Old 14th November 2002, 08:15 PM   #29
Dragance007's Avatar
Send a message via ICQ to Dragance007
or are you an
No, No, I Am Just a guy that likes to buid amplifiers but there are may "SO(SELF) CALLED" DJ's around me and diskoteks that ask me for that much power so i wanted to know since i don't have proper tanformer is it Posible ????
Old 15th November 2002, 09:05 AM   #30
Hehehe, I know those guys !!!
just for fun:
Just let them hear a good 100/200W amp with good speakers (with high sensitivity) and play at almost full power (the whole room is thrilling) and ask them 'how many watts' they think that's playing. They would be amazed that it's 'only' a 100 or 200W.
HB.
Page generated in 0.13171 seconds (86.09% PHP - 13.91% MySQL) with 10 queries
