problem with leach amp
Old 24th February 2005, 10:33 PM   #1
xxsmiffxx is offline xxsmiffxx  United States
Send a message via AIM to xxsmiffxx
Default problem with leach amp
I just got done seembling this amp, and I keep on blowing r51. I have thoroughly checked the board for solder bridges and things like this, but I am having no luck. Anyone have any idea what I might have done wrong to cause this problem? Thanks in advance!
David Smith
David Smith
Custom Creations
Old 25th February 2005, 03:50 AM   #2
djk is offline djk
djk's Avatar
R51 blows because you have a ground loop.
Old 25th February 2005, 04:46 AM   #3
thanks for the quick reply! So there is a problem with my ground path? I have everything grounded to a single point on my chassis. Could this be a problem on the board or is it likely a wiring issue? Thanks for your patience with me, I am new!
David Smith
Custom Creations
Old 25th February 2005, 05:39 AM   #4
djk is offline djk
djk's Avatar
"I have everything grounded to a single point on my chassis."
I hope you followed the instructions to the letter at Leach.
The input and output jacks do not make electrical contact to the rear panel.
Re-read all the instructions.
Old 25th February 2005, 08:30 AM   #5
My input and output jacks are isolated from the chassis ground. The only parts grounded to central point are the ones marked for central ground. Thanks again for any suggestions, and I will continue to re-read instructions to insure I haven't made obvious errors. Again, thanks for your patience!
David Smith
Custom Creations
Old 25th February 2005, 08:50 PM   #6
djk is offline djk
djk's Avatar
If the input jacks are floating, the only way R51 can conduct is if there is a difference in potential between the amp chassis and whatever you have driving it.
This is normally called a ground loop.
Replace R51 and add a pair of diodes in parallel, one reversed from the other, bypass the resistor with a 0.1F film cap.
This will stop the resistor from blowing and give you a loud 'buzz' to tell you youhave a ground loop to troubleshoot.
The 'hot' and 'neutral' on and piece in your system may be backwards. The power supply of the amplifier may have high leakage current.
In the worst case an input transformer may be required.
problem with leach ampHide this!Advertise here!
Leach amp treble problem fabix Solid State 5 19th February 2009 02:40 PM
possible leach problem?? rtate Solid State 7 23rd October 2008 05:35 PM
Leach amp problem Curioprop Solid State 95 1st September 2008 10:58 AM
Problem with leach amp AudioG Solid State 1 8th June 2005 03:40 PM
Leach amp problem Ed LaFontaine Solid State 3 19th July 2004 01:04 AM
Copyright ©1999-2017 diyAudio
