Hi all,
I am fixing an audio research D-100B power amp. I think the output power transistors are dead. I don't know the part number printed on the transistor cover. What printed on the cover are motorola 300027 7926 and motorola 300026 7852. Apparently, they are complementary pair. I think the number is only for audio research interior reference. Anybody knows what they are?? Thanks alot! Lhchen
The best way to stop rust on transformers is to power them up. |
#2 |
If they are motorola in TO-3 cans you can bet they are MJ15003/04 or MJ15024/25. In any case either of these should drop right in and work identically.
#3 |
Thanks for the help. They use 6 pairs of pnp and npn power transistors in parallel to produce only 100 watts output at +55v -0- -55v voltage. So, it's very unlikely to be one of those that we often use. Those transistors must be out of production nowadays and long not availible. I am looking for substitutions, still motorola ? no sanken? Thanks for any coment. Lhchen
#4 |
Yes, still Motorola/on semiconductor. No not Sanken if you want it to live for a while. As mentioned by jaycee either of the motorola parts will work. |
#5 |
Sanken and Toshiba no longer produce meatal can T0-3 bipolar output devices. Motorola is almost the only source
These three companies produce very reliable transistors, but Sanken and Toshiba suffer more from fakes in the American and European markets |
#6 |
Wait a minute!!
After I opened up the chassis, I found out 6 pairs of NTE60/61 each channel. We know NTE60/61 are equivalent to MJ15003/15004. My Audio Research D100b got only output at 100 watts at 8 ohm. At B+ as 55v-0v+55v, what would be the output rating? Where are those transistors from? Somebody put them in? For extra power? Am I missing something here? Oh My! I bought a lemon. Lhchen
#7 |
"Thanks for the help. They use 6 pairs of pnp and npn power transistors in parallel to produce only 100 watts output at +55v -0- -55v voltage. So, it's very unlikely to be one of those that we often use. Those transistors must be out of production nowadays and long not availible.
I am looking for substitutions, still motorola ? no sanken? Thanks for any coment." Why not use what Audio Research used? The date codes indicate the 78~79 vintage, the MJ15022/23 was just showing up in amplifiers, that's probably what they are. Take a dead one and cut the top off and look! If not an MJ15022/23 they are most likely MJ15003/04. |
| Fet dravers part number? | Bad silver | Car Audio | 2 | 22nd June 2009 05:52 PM |
| Jfet part number | mmerig | Parts | 5 | 23rd September 2007 04:19 PM |
| Need part number for a transformer | bluegti | Chip Amps | 16 | 27th December 2006 03:06 AM |
| plitron part number for UCD400 | onixuser | Class D | 3 | 16th February 2005 07:24 AM |
| Page generated in 0.10369 seconds (78.79% PHP - 21.21% MySQL) with 10 queries |
