pioneer SA-6500 II problem
Old 23rd February 2005, 08:57 PM   #1
udip is offline udip
udip's Avatar
Default pioneer SA-6500 II problem
Hi all,
I hope you can help me with this one...
I have an old pioneer stereo amplifier from the 70's.
The model is SA-6500 II.
It's working ok, and it sounds extremly good, but there is
one problem: when I turn it on I have a big thumb for a second
or two...like big mmmmmm, so I always turn it on with the speakers' switch in off position, waits few seconds, and then turn the switch back on....
I think it's a dc offset problem, or maybe bias problem,
anyone has a clue on how to fix it? or anyone knows
where can I find the schematic?
Thanks in advance,
Udi.
"Things should be as simple as possible, but no simpler"
Albert Einstein
Old 23rd February 2005, 09:21 PM   #2
K-amps is offline K-amps  United States
K-amps's Avatar
There's a good change the electrolytic caps on that have dried up. They may need replacing. DC offset does not cause "MMMMM" for a sec or two... neither does bias... they usually cause it for a long time of out of whack.
Try replacing the samller caps around the input stages, seems like the input bias circuit has a defective capacitor.
Old 23rd February 2005, 09:32 PM   #3
udip's Avatar
Hi K-amps,
Thanks for the reply...
In fact, I have this problem for a few years now, and last year
I replaced all the electrolitic capacitors in the amp
(except for the power supply capacitors), and it didn't help,
and in fact the sound got worse , but I guess this
is because I used cheap capacitors.
You think maybe it's the power supply capacitors?
Udi.
Albert Einstein
Old 23rd February 2005, 09:42 PM   #4
EchoWars is offline EchoWars  United States
EchoWars's Avatar
Doesn't that model have a relay? If so, it should take about 3 or 4 seconds to kick in.
Old 23rd February 2005, 09:45 PM   #5
udip's Avatar
I think it doesn't have a relay, but it has inductors with resistors
in parallel at the outputs.
Maybe I should add a relay (or two) ??
Udi.
Albert Einstein
Old 23rd February 2005, 10:06 PM   #6
K-amps's Avatar
The 6500II did not have relays. Yes the larger caps might need replacement.
Old 23rd February 2005, 10:23 PM   #7
udip's Avatar
Thanks guys,
I'll try replacing the supply caps.
Udi.
Albert Einstein
Old 20th October 2005, 09:28 PM   #8
munja is offline munja  Croatia
Hello udip,
do You solve that problem about bad sounds through switching amp on?
I received Pioneer SA-8500 with similar problem (left channel only), but here at me it works fine, I should wait until it sounds would appear!
I think the problems lying in some active component (diode or transistor), amp is very old and semiconductors change their characteristics.
Let us find it!!!
Regards, Munja
Old 12th March 2009, 08:06 PM   #9
lespoils is offline lespoils  Canada
hi,
I got the same amp but a different problem. i have distortion in the right channel. The left one sounds fine.
could that be Dc offset ?
thx
Old 11th March 2011, 11:06 AM   #10
andrewcrawford is offline andrewcrawford
Default Help
I have a 1974 Pionner SA-6500 II amp that was givin to me 12 yrs ago and it has worked fine all these years but a few years back a friend of mine fliped it on and i guess was listing to rap and roasted the speakers to the point of setting them on fire the board isnt burnt any where i have been able to find but it still will not put out any sound on a loud buzzing noise any one that help me i would be greatfull
pioneer SA-6500 II problemHide this!Advertise here!
Pioneer SX-838 problem b17man Solid State 2 13th May 2009 12:57 PM
sansui qrx 6500 east electronics Solid State 2 5th November 2008 11:15 PM
Schematic Soundstrean XXX 6500 JoergST Car Audio 0 1st August 2007 07:32 PM
Mounting Polk Sr 6500's Stewart8989 Car Audio 3 11th March 2007 06:40 AM
Copyright ©1999-2017 diyAudio
