grounding....
grounding....
Old 4th August 2001, 09:19 AM   #11
ALW is offline ALW  United Kingdom
>For the art of PCB my professor always says that the diffrent layers must be rotate of 90°.
This is good practice, but is mainly done to make routing tracks efficient.
Old 4th August 2001, 10:34 AM   #12
Petter is offline Petter
Default Orthogonality
tracks that are at right angle to one another have minimal magnetic interference. High frequency circuits are usually set up this way.
Petter
Old 14th August 2001, 12:56 AM   #13
haldor is offline haldor  United States
Default Re: Choices...
Originally posted by ALW
If the amplifier runs from a dual rail supply (+ve, -ve), make a sturdy connection between the PSU reservoir capacitors at the earth point, and return all earths to this point. This is a sonically optimal solution.
Andy. [/B]
Hi Andy,
'D. Self' makes the suggestion that if you are going to do use this kind of grounding scheme that it is best to make the star ground connection on a stub off to one side of the heavy trace between the supply caps not to the heavy trace itself. His point is that there can be extremely large currents flowing in the trace between the two caps and by moving the star ground off to one side you eliminate the possibility that one ground trace feeding into the star ground might see a different ground reference than another.
Phil
grounding....Hide this!Advertise here!
The grounding Professor smith Pass Labs 100 4th July 2009 03:19 AM
some help on dac grounding, please federico moreno Digital Line Level 0 3rd April 2009 05:05 PM
Lions and Tigers and Grounding Problems, Oh My! DoZ Grounding... EchoWars Solid State 37 3rd August 2008 08:50 AM
Grounding tonistefanovski Pass Labs 5 15th November 2006 01:37 PM
LM3875 kit grounding, optimal grounding for separate amps and psu? findog Chip Amps 9 16th May 2005 09:27 PM
