Old 20th February 2005, 08:53 PM   #1
DREW028 is online now DREW028  United States
Send a message via AIM to DREW028
Default searching for transistors
need help find a place to order some transistors....i need 8 transistors that say NEC k3057 and 2 that say f12c10a and 2 that say f12c10c.
Old 20th February 2005, 09:03 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Would it help you to say that K3057 is 2sk3057 which is a mosfet
and F12C10A/C are power diodes/rectifiers made by Mospec.
Datasheets can be found at datasheetarchive.com
Perhaps this will help in your search for the parts.
/Hugo
Old 20th February 2005, 09:25 PM   #3
thanks..but min order of $300 ..i only need 12 things total
Old 20th February 2005, 09:31 PM   #4
Netlist's Avatar
Oh...but you don't have to order at datasheetarchive.
Only, I wouldn't know where to get them in the states.
Didikey, Mouser perhaps?
/Hugo
Old 21st February 2005, 01:51 AM   #5
Default NTE numbers
The nte part numbers for 10a is 6244 and 6240 for the 10c . digikey probaly has the parts or it will show you subs sometime also .
Will it hurt if I touch that
Old 21st February 2005, 02:26 AM   #6
nte?...sorry i new to this (fixing electronics) although i have fixed several things before..couple of amps,radios...i am 17 and this is something i enjoy doing and plan on building up my knowledge of so any help is very appreciated.
Thanks.
Old 21st February 2005, 09:36 PM   #7
Default NTE
Oh NTE is a company that makes semiconductors.Every company has different part numbers for similiar parts.The only cross reference book I have with me is NTE. Here are somelinks to companies that sell parts . You can type in those part numbers and they will list parts they have and prices , and substitutes.Its best to use original if you can get them.
http://www.mouser.com
http://www.digikey.com/
http://www.newark.com/
Its good to try a few places because prices can be very different.
Old 21st February 2005, 10:00 PM   #8
Default Be Carefull
Also if your new be very carefull . Electricity is dangerous .You might want to check local technology schools sometimes they have night or weekend classes that are pretty good and cheap.If all those parts are bad there may be something else wrong that isnt so obvious so you may burn those parts up again.Just remember to respect the electricity.When you solder those things , use some flux and clean the pads . search the forums there probably some really good how to's on here.Some boards have a coating on them and its best to get it off first , I have seen a lot of people burn threw with solder iron but that bad for board and components. They make stuff called conformal coating remover and it works great.it should only take a few seconds to get solder to flow.If it takes longer you may burn the component up or lift pads.Clean it with rubbbing alchol first, dirty boards and parts dont solder well.Use an electronic flux and thin solder.
Old 26th March 2005, 07:44 AM   #9
sellb is offline sellb  South Korea
Send a message via AIM to sellb Send a message via MSN to sellb Send a message via Yahoo to sellb
Default Datasheet search engine
http://www.datasheet4u.com
Old 26th March 2005, 03:51 PM   #10
anatech is offline anatech  Canada
anatech's Avatar
With all due respect to dherr555, DO NOT USE ECG / NTE parts unless there is absolutely no other choice. You can not trust their subs or their sub book for proper devices. This stuff may work for TV and some industrial applications, but not for audio. That and their stuff is generally more expensive that the original devices.
-Chris
(re)searching for a better preamp carlosfm Chip Amps 692 12th April 2012 08:11 PM
searching a ESX Q 275.2 or 175.2 pit bull Car Audio 1 7th December 2008 08:46 PM
Searching... Cortez Forum Problems 1 27th April 2006 12:23 AM
Searching for an Amp Projekt for +-50V BlacK_Chicken Solid State 13 19th December 2005 12:35 PM
Searching for this guy Guss The Lounge 1 3rd August 2003 11:04 PM
Page generated in 0.10153 seconds (76.63% PHP - 23.37% MySQL) with 10 queries
