Old 20th February 2005, 08:02 AM   #1
Banned
Default Mosfets are they that sensitive? like if i touch its pins then will they be destroyed
Mosfets are they very sensitive?
what i mean to say that do they get destroy if i touch them with fingers?
I want to make amps using this but as far as this was my doubt and ive never laid my hands on this MOSFETS coz im afraid of destroying while handling that....
what do u say....?
Old 20th February 2005, 08:23 AM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
In your case, I enter the site’s search engine and in the row
‘Search for items including these words:’ I would enter ‘mosfet static’. Then click below on 'Show results as posts', leave everything else alone and hit the ‘Perform search’ button.
Now try that, do some reading and report your findings.
/Hugo
Old 20th February 2005, 07:02 PM   #3
Default mosfets don't like static
Yes, mosfets are easily damaged by static, as are many modern devices. Sometimes the damage doesn't show up til the devices have been working for hours, days or months; the worst sort of damage.
It isn't hard to take precautions though - get yourself an antistatic mat and wristband, connect them and your soldering iron to earth and keep your cutters, pliers etc on the mat in between tweezes and snips.
http://tinyurl.com/4vl92
if that's too expensive, you could use a sheet of alumin(i)um foil on your table - proper antistatic mats are better though as they don't conduct enough to short low voltage circuits lying on the mat.
good luck, don't be scared!
Old 20th February 2005, 07:48 PM   #4
Banned
Breman ur are very nice and u have good helping nature and ur not like Netlist. guy...who said that just go to google and try there...( ooooooooh we dont know that... aah ) ok NetList i think first before u post anything like this think that if anybody says this to you like go to google and search urself...
and one more thing if we get the all the answers at google then what is the need to come to the diy audio forums ? we ask u becoz we newbies we treat you like experts and genius people who have tons of experience and we think that u may give the right advice ... but uuuuuuu see how u are hurting newbies..
Just think about urself before posting something like this...
Be helpful in nature....
Old 20th February 2005, 08:05 PM   #5
Netlist's Avatar
Don't blame me because I explained you how to search.
The power lies in the possession to find what you want and need. Helplessness is the opposite.
We could spoon-feed you all you want, in the end you will have learned nothing.
/Hugo
Old 20th February 2005, 08:35 PM   #6
Did it Himself
richie00boy's Avatar
The nice Mr Netlist (and he is nice, if you would bother) was actually telling you how to search diyAudio not Google. So your point is in the garbage. Just try to use the search function of the forum before you post, that's all we ask. You may well be suprised at what turns up
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 20th February 2005, 11:01 PM   #7
georgehifi's Avatar
Send a message via MSN to georgehifi
Standing back and reading the flack that's going back and forth. To me I can see that the original question was a valid one and and a good thread starter.
Then on the other foot Netlist and richie00boy have a valid point also. Though they should not include the word (we) they should use (i)
I looked at this thread as a source of information, not to tell diysmartdeep21 to go search for himself.
So in future Netlist and richie00boy do'nt use (we) as i did'nt mind the original topic. Use (I).
Cheers All, George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 20th February 2005, 11:13 PM   #8
I have started to post a few questions on this forum and each time I have to confirm a search.
Well I have searched and found hundreds of references and even taken time to read many (I cannot claim most) and I have NEVER found what I needed to know. Maybe I am no good at searching the right phrases. Can someone give me lessons?
I've done it again, a question without a search (it's easier this way).
regards Andrew T.
Old 20th February 2005, 11:52 PM   #9
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Both of the last two posts present very good point. This forum has so much accumulated information, that if we all were skilled in searching, there would be probably not much reason to start new threads.
So what, that something has been discussed already? Maybe the point was not made, or the new discussion will bring more light on a given subject. I also noticed that threads that were started 2 years ago, even when resurrected, for some reason never bring interesting discussion again. That's what threads are all about: they are being started, have certain lifespan, and then they die. The new ones (even when regarding same topics), are always different.
Getting back to the subject at hand, as long as you make sure that you will not produce static (like for instance you touch a grounded object before handling mosfets) and your working area is pretty much static free, you shouldn't have problem with touching the pins. I never managed to damaged a mosfet this way.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 21st February 2005, 01:51 AM   #10
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
In my experience, power MOSFETs and IGBTs with big die sizes and several nF input capacitances are very tolerant to moderate human body static discharges
However, small signal MOSFETs and CMOS ICs are not so tolerant, but they tend to include protective diodes internally
I've tested some power devices after handling them and soldering them without precautions and no gate leakage was measurable
Bigger gate structures are apparently capable of whitstanding bigger static discharges
Are my two TDA1562 destroyed?? newbadboy Chip Amps 2 10th June 2009 12:13 PM
Touch sensitive sound modulation New2Electronics Everything Else 2 13th April 2009 03:28 PM
destroyed 10" Animalnisse Swap Meet 0 8th January 2007 02:19 AM
SG3525 destroyed MOSFETs SMPS3525 Power Supplies 16 21st September 2006 12:38 AM
Is SAA7378GP destroyed? Gasho Digital Source 5 8th August 2005 04:10 PM
Page generated in 0.14941 seconds (70.05% PHP - 29.95% MySQL) with 10 queries
