I set up this adapter board for replacing the NE5532 with a pair of AD825's and 0603 decoupling capacitors -- there is the option of connecting pin 4 to V-, or connecting it to ground for single-supply operation.
if there is interest I can have some made. They are a bit small to cut on a table saw, probably will have to design rows of holes so they can be snapped apart. http://www.tech-diy.com/ad825_adapter.htm
#2 |
Like this ?
#3 |
I thought of top and bottom mounting, but if the AD825 runs to its maximum capacity you will probably shorten its life dramatically. there is no airflow to the bottom chip so it will really cook.
#4 |
What is maximum capacity ? Output current +/- 50 mA ? In 99 % cases op amp run by much lower conditions. BTW this design is universal, not only for 825 and I don't observe any disturbing by using of this aid
#5 |
figure it will dissipate ~ 100mW quiescent.
there are better dual opamps from ADI anyway. |
#6 |
Gerber files of the double sided version would be nice.
Looks like Sponge Bob has killed another thread. |
#7 |
does this seem correct to you?
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease |
#8 |
The bottom uses thicker traces because I had the place to make them thicker. Making them as thin as the top planes can be done without problems.
#9 |
To Bricolo : Aren't traces on top side uncorrect ?
#10 |
What's wrong?
The 2 sides are printed in mirored mode, maybe that's wrong.
| AD825 alternatives? | woodturner-fran | Parts | 0 | 27th November 2008 11:41 AM |
| WTB: AD825 opamps | Mark Hathaway | Swap Meet | 7 | 22nd May 2004 07:59 PM |
| Need some AD825's | rbroer | Parts | 1 | 17th February 2004 09:37 AM |
| AD825 Op Amp..anyone familiar with it?? | MrGuitardeath | Solid State | 4 | 4th December 2003 07:40 PM |
| ad826 vs ad825 (using adapter) | jarthel | Digital Source | 1 | 26th April 2002 07:31 AM |
| Page generated in 0.10760 seconds (79.88% PHP - 20.12% MySQL) with 11 queries |
