Hi all,
Hafler 200/220/280 employed parallel output transistors .. is there any advantage in terms of sound quality to use only 1 pair of 134/49 per channel ? I do understand I will have less power but would I gain in better sound? Regards, Tom |
#2 |
You will lose the current capacity of multiple outputs, that really can change the sound of an amp when driving tougher loads. Some argue that it is hard to get two of the same transistor to track each other perfectly and that can make the arguement for using only one output. I like the slam of more current and think that most modern devices are fast enough to mask any differences in the audio spectrum.
If it sounds good... it is good! |
| Could someone explain this Hafler/Strickland output topology to me? | SQLGuy | Solid State | 86 | 1st February 2009 05:38 PM |
| Replacing Hafler 9130 transistors- 2 techie question | reiver | Solid State | 5 | 12th June 2008 12:15 PM |
| FS. Hafler DH 500 power transistors complete set. | AcidJazz | Swap Meet | 3 | 20th May 2008 01:46 AM |
| Selling some Hafler DH-220/DH-500 transistors | housing | Swap Meet | 0 | 10th May 2007 03:43 PM |
| Hafler output FET's | testlab | Parts | 0 | 21st December 2005 05:12 PM |
| Page generated in 0.06236 seconds (69.53% PHP - 30.47% MySQL) with 10 queries |
