Hi all,
I'm looking for a simple discrete line buffer, that could be direct coupled, could drive 1k load, and most important, that will have balanced output. I was thinking about borbely fet buffer (figure 15c in JFETS 2 article on his website), since in theory it has zero offset. Can I get balanced output from such a simple circuit, by taking the cold output from a resistor in series with ground? (I think that most important thing in balanced lines is that the reciever should see equal impedances at both inputs), And if so, what should be the resistor value? Thanks in advance, Udi.
"Things should be as simple as possible, but no simpler" Albert Einstein |
#2 |
Does anyone know a good discrete buffer with balanced
output?
#3 |
Borbely has a balanced line amp design, and I wonder if I could use feedback in order to control gain. The problem is that it's balanced, so I don't know exactly how to do it. Maybe I can use two feedback paths, from outputs to inputs? Any ideas? Thanks, Udi.
#4 |
Not sure what you request is.Is it balanced in/balanced out OR unbalanced in/balanced out???????
#5 |
Hi!I like balanced in/balanced out
Justice for Victims of Agent Orange http://www.petitiononline.com/AOVN/Thank all of you! |
#6 | |
Hi, I'm looking for a buffer with unbalanced input and balanced outputs. If it haz balanced input, that's ok, cause I can always tie one input to ground. The problem I have is how to control the gain in the circuit, because it's unknown to me... I need gain between 0-6 db... Udi.
#7 |
How about this circuit? will it work?
#8 |
cenrtailnty, but without dc-feedback
#9 | |
#10 |
Absolutely no!The COLD end would be appear like the input of a power amp grounded!
| Balanced jfet buffer for Vout DAC? | jonners | Solid State | 7 | 22nd October 2010 07:57 AM |
| current buffer for cd output | maxpou | Digital Source | 0 | 14th February 2008 04:14 PM |
| IRF9530 as pre output buffer | wleediy | Solid State | 11 | 23rd January 2008 09:36 AM |
| Simple buffer for balanced inputs? | Nisbeth | Solid State | 6 | 25th October 2005 06:24 PM |
| Balanced ADC buffer | fmak | Digital Source | 0 | 11th February 2003 05:29 PM |
| Page generated in 0.10545 seconds (75.54% PHP - 24.46% MySQL) with 11 queries |
