> Input sensitivity (for rated output into 8 ohms) 1.1V
Input sensitivity 0.77V
With the second amp no load is mentioned. What does the manufacturer mean?
Input sensitivity shouldn't be much dependent on load as audio amps are voltage amplifiers
Yes, but they are not perfect voltage sources.
Rated output voltage varies with load.
A typical amp may be rated 160 Watts in 4 ohms, 100 Watts in 8 ohms, 60 watts in 16 ohms.
In voltage, these are 25V in 4 ohms, 28V in 8 ohms, 31V in 16 ohms.
The power supply sags as the load resistance decreases. A 20% sag is not at all uncommon.
The amplifier voltage gain is probably constant over this range of loads. If damping factor is 1,000, then the voltage gain drops 0.01%, not enough to measure easily.
Gain might be 20 (+/-0.01%).
So the input sensitivity is 25V/20= 1.25V in 4 ohms, 28V/20= 1.4V in 8 ohms, 31V/20= 1.55V in 16 ohms.
The range from 1.25V to 1.55V is measurable but probably not very important.
One maker choose to say what the test load was, the other didn't. This is often NOT a designer decision, but some manual-writer who just barely knows what an amplifier is.
The older mainstream amplifiers used to almost double the output power on 4 ohm loads (ie Marantz 500). Unless you spend $$$ on a new amp, forget it. Power transformers and heatsinks add weight and cost money. You will therefore find the minimum (or lower) capasity installed in newer avaerage consumer grade amplifiers.
Methinks you are idealistic there darkfenriz. I've said it before. Early on, we consumers voted for crap with our dollars, now that's about all there is in the mainstream. Yeah us! And that's what DIY is all about.
-Chris
-Chris
- Input sensitivity
