Old 18th February 2005, 06:31 AM   #1
djdamix is offline djdamix  France
Default Big power for 8 ohms subwoofer
I need big power for 8 ohms subwooferI was wandering what is the best solution to have big power under 8 ohm (about 700W). Single class AB amp will need >100V DC rails, and so special MOSFET, not the IRFP240 I 'm used to use.
and also high voltage more expensive caps
The second solution could be to bridge two amp (stable under 4 ohms).
Any advice on that choice ??? What'is the most common solution for such a power ? I haven't seen much design providing such a power.
David
Old 18th February 2005, 10:48 AM   #2
or maybe someone can give me a link with a big power MOSFET amp schematic under 8 ohm ...
Old 18th February 2005, 11:24 AM   #3
Did it Himself
richie00boy's Avatar
Go bridged. Bridging better for high power anyway as it allows high slew rate, is much better on the PSU, and keeps large currents out of ground.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 18th February 2005, 11:39 AM   #4
Ok thanks, I'll try bridging
WANTED: Subwoofer Plate Amplifier (500W RMS / 4 Ohms) ViperZ Swap Meet 1 1st February 2010 02:36 AM
power amplifier 400w @ 4 ohms divojara Solid State 8 22nd June 2007 06:54 AM
Suggestion for Power AMP ! 150W @ Ohms -_nando-_ Solid State 11 1st October 2006 09:12 PM
ESP 3A output power at 4 ohms load Freddie Solid State 19 5th January 2004 06:02 PM
aleph 5 power into 4 ohms lowfi Pass Labs 3 24th October 2002 06:07 PM
Page generated in 0.06920 seconds (70.27% PHP - 29.73% MySQL) with 10 queries
