Please comments on the attach simple IC line amp !
1) What will the performance, is it worth to build ? 2) The value of components ? 3)What will you think if the arrangement of U1 to U3 :- a) opa 134, opa134, opa134 b) opa 134, op637, opa134 c)op627, op 673, op 627 (because the data sheet show 627 has better performance with no gain) d) or any better choice ! (The price is great difference between 134 and 637 !!!!) 4) Can any one advise me some simple good O.P."Phono & Line" pre-amp schemtic & PCB layout ! Many Thanks ! |
#2 |
Simple? Most people would say a single opamp is sufficient for this application. Still, there is a benefit in buffering the volume pot and it certainly allows a very low value for the pot to be used.
But what is the third opamp for? I can see no reason... |
#3 |
the third is an output buffer.To me,100k is enough for input resistor,need not 1M.The circuitry looks fine to me and sure it will work as it is a pretty standard circuitry.Just pay attention to layout and wiring during assembly
#4 | |
#5 |
Output Buffer is to deal with low-Z loads, since the 2-nd opamp has high GAIN /10-11/ and will suffer from higher distortion, because it's feedback is 10-11 times lower than the 3-rd opamp. Also it is good the 3-rd opamp to be a very fast Amp like AD811 or similar and OP2 and OP3 work with a common feedback loop, I've seen this on numerous designs of Headphone ams and pre-amps like this.
#6 | |
#7 | |
Banned
And like analog_sa says, the last op-amp is not needed at all. Avoid what you don't need. |
#8 |
if you want to improve on line amp performance with extra op amps you really need to read Walt Jung's composite Line Driver and Op Amp Audio articles:
http://home.comcast.net/~walt-jung/w...7s-20PDFs.html noise performance is definitely an issue with the 1x buffer in front of the attn. if the headroom requirements premit with the sources you have I would move as much gain as possible up front to minimize noise |
| Page generated in 0.08929 seconds (73.64% PHP - 26.36% MySQL) with 10 queries |
