marantz 1060 makes frying  noise at power-up
Old 17th February 2005, 03:44 PM   #1
pronto89 is offline pronto89  Italy
Default marantz 1060 makes frying noise at power-up
Hi folks,
my 1060 was making a like-frying noise from inside for few seconds at power-up then everything was fine. Till yesterday when a defective AC socket caused the 1.5A fuse to blow up. Now I substituted the fuse but now the noise can be heard from speakers too, always only for few seconds at power-up.
I asked a pair of shop here for repair, but they look more as board-changer and they told me that is too old to get repaired.
Now, all caps and other components look ok from outside, any idea?
Old 17th February 2005, 05:39 PM   #2
pamaz is online now pamaz  Italy
Default 1060 in italy is always a problem!
Hi. seems that 1060 do not like spaghetti.
My 30 & more years old 1060 does the same and now it's in his box!
if you find the solution, I'll be happy too.
probably one day i'll take it out of the box and try to fix it .
buona fortuna
paolo
Old 17th February 2005, 11:54 PM   #3
NUTTTR is offline NUTTTR  Australia
Are you sure it's not a dodgy switch on the amp causing static-sound through the power supply? I used to have that on a NAD amp.... turned out to be a simple switch problem!
Aaron
Old 18th February 2005, 12:25 AM   #4
anatech is offline anatech  Canada
anatech's Avatar
Hi pronto89,
NUTTTR is on the right track here. Bad switch contacts arcing. Replace the power switch and install an MOV across the transformer primary. I have seen bent PCB fuse holder contacts do the same thing. The MOV will extend the life of your power switch and protect your amp from voltage spikes.
-Chris
Old 18th February 2005, 01:54 AM   #5
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Wow! Another 1060 problem in Italy!
Watch out for the power switch. Mine is sloppy too, it needs heavy pressure to stay on.
Old 18th February 2005, 09:42 AM   #6
I'll try this evening with the switch and will let you know
Old 19th February 2005, 08:48 AM   #7
Default Great!
Yes, it was the switch.
Substituted with a solid tin bridge and no more frying!
Now I'm going to Rome to find some replacement switch.
Hope to find it since I'm rather new to this town and I've no idea where to go.
Thanks for the solution.
marantz 1060 makes frying  noise at power-upHide this!Advertise here!
marantz 1060 transformer naimgame Solid State 3 17th March 2011 10:37 PM
OMG my DCX just started the frying-egg noise problem :( DIY_newbie Digital Line Level 3 3rd April 2008 12:54 AM
Marantz 1060 parts KCravens Solid State 1 29th February 2008 11:12 PM
Picked up a Marantz 1060. negah Solid State 10 10th December 2007 09:07 PM
Frying noise in one channel of a 6ch amp Thunau Solid State 3 1st November 2003 02:35 AM
