This is my first post here.
I like to introduce my new CCS. This is just an idea. I did not test it yet. Have you ever seen before? I like to know your opinion or comment. Thank you. |
#2 |
Sijosae,
VERY neat idea! I haven't seen it before. I think it will clearly improve on the Vb stability over the left side diagram. I have a few questions, though. With the high quality of the 317 as current source, most likely the current through the 317 is more stable than the current through the transistor. The current through the transistor is still depending on variations in Vbe, temperature and even voltage. So, if your aim is a very constant, high impedance current source, the 317 alone is probably better then in combination with the transistor. Just some thoughts. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#3 |
I just tested this new CCS as follows.
V+ : mA 1.86 : 0.000 2.41 : 0.533 2.86 : 1.236 3.05 : 1.243 3.61 : 1.249 4.50 : 1.250 6.93 : 1.251 10.63 : 1.255 12.39 : 1.256 14.79 : 1.257 (2N2222 - 500 ohm, LM317L - 300 ohm) IMHO, it shows very good results. |
#4 |
Another application of this idea is a replacement of the zener diodes in the power supply. (voltage reference)
By using LM78xx ICs, we can get various and high voltage voltage reference simply. e.g. LM7824 --> as a 24V zener diode. |
#5 | |
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#6 | |
But what is the variation in Vb with the same steps? That will tell you what is better, just the 317 or the 317+transistor. Jan Didden
#7 |
Thanks Jan Didden,
I completely agree with you. Yes. I know the current through the LM317 is more stable. However there is a lower limitation in the current. (datasheet of the LM317L) In that case, current should be > 5 mA. |
#8 | |
Indeed, you're more flexible this way. Good thinking. Jan Didden
#9 |
Interesting idea, Sijosae.
However, the voltage reference will always require a prescribed current from the collector source which will vary very slightly as the potential stress across the LM317 increases. Is this a good thing? Another option might be to run the LM317 from another power rail (positive with respect the to the LED anode) and then run a resistor from this same rail to the emitter. Chosen correctly, this should compensate changes in Vbe with rising and falling voltage at the collector. This is an Elektor idea, incidentally, not my IP at all! Cheers, Hugh |
#10 |
Here is an accurate CCS with a voltage reference I have used several years with good results, and it don't get much better...
Cheers
"If transistors are blueberries and FETs are strawberries, then tubes must be.. pears" Michael 29th January 2010 |
| Different pre amp idea | bartek | Solid State | 3 | 25th March 2008 03:42 PM |
| I really have no idea what I'm doing here... | d to the g | Multi-Way | 10 | 7th March 2008 06:04 PM |
| P.S idea | noyan | Power Supplies | 15 | 19th December 2007 08:50 PM |
| An idea! Fully balanced TDA1541A DAC idea. Please comment! | cartman | Digital Source | 8 | 17th July 2007 08:18 AM |
| Just an idea | bob123 | Subwoofers | 4 | 9th April 2006 02:28 PM |
| Page generated in 0.12075 seconds (78.45% PHP - 21.55% MySQL) with 11 queries |
