Hello!
At the moment I´m constructing an active 3-way filter design for my new speaker project. During calculating process I´ve got an idea: Why not add a DC voltage to the audio signal after the input buffer, so the op-amps in the following stages always work with positive (or negative) amplitudes ?!? In my opinion this would avoid zero-crossing dissortions! ![]() (e.g. added DC +5V when audio signal range +/- 2,5 V -> chips work between +2,5 and +7,5 V) The added voltage would be easy filtered by the coupling capacitor at the output . Do you think this concept makes sense ??? greets Peter |
#2 | |
#3 | |
Warp Engineer
On Holiday
- Dan |
#4 |
Cap will be polarised, giving strange noises.
Miguel |
#5 |
Fundamentally, the switch-over from one output device to the other happens at zero output current, not at zero voltage. There could be a significant voltage on the output at this instant; that doesn't matter (and this will always be the case with a reactive load, such as a filter). Once you realise that the N type output device can only ever source current, and the P type one can only ever sink current, you'll be closer to understanding.
#6 |
I know that Rupert Neve uses this method. The crossover distortion is much less noticeable since it only occurs at high signal levels
#7 |
It would work... as long as the op-amp was DC coupled to the next stage so it's always sourcing current to the input impedance of the next stage. A waste of power for little, if any, benefit in my opinion. If you really want a class-A op-amp then build one from discretes.
https://mrevil.asvachin.eu/ |
#8 | |
#9 |
Consider adding a pull-down resistor (or current) to -V.
This has the effect you desire, running the output NPN always on. Calculate the peak "sunk" current, and make the DC bias higher. This is an old trick to force class a operation. Best Regards,
Steve Beccue |
#10 |
Account Disabled
You need to do this cautiously, with a distortion analyser attached or you may exchange one distortion for another. OK if your seeking euphonics, bit like eugenics?
| Crossing near Fs | goldyrathore | Multi-Way | 3 | 27th July 2009 11:28 AM |
| Low crossing of Compression drivers | reins | Multi-Way | 4 | 8th September 2007 07:28 PM |
| Crossing Over Jordan | Jim Griffin | Multi-Way | 33 | 17th June 2006 01:15 AM |
| Crossing to a sub? | smbrown | Multi-Way | 1 | 6th August 2004 01:10 PM |
| Page generated in 0.11166 seconds (78.95% PHP - 21.05% MySQL) with 10 queries |
