Old 15th February 2005, 04:41 PM   #1
B.I.G is offline B.I.G  Romania
Default Holton separate power supply for imp/output!
i would like to use separate powersupplys for the imput and output of the amplifier .... the imput pws should be about 5v higher than the output. i heard this could make the amp more eficient! is that true ? why is that ?
B.I.G
Old 15th February 2005, 04:43 PM   #2
oh i forgot it`s for Holton`s 400W symetrical amp http://www.aussieamplifiers.com/down...ed%20AV400.pdf
B.I.G
Old 15th February 2005, 04:52 PM   #3
Mr Evil is offline Mr Evil  United Kingdom
It is true. It's because MOSFETs need a certain voltage between gate and source to turn fully on. If the driver stage has the same voltage rails as the output stage then the gates can only ever be taken up to rail voltage at most. This means that the sources (and thus the output) will only be able to reach Vgs less than the rails.
With higher rails for the driver stage then the gates can be taken above the output stage rails and thus the sources can reach very close to the (output stage) rails, effectively increasing efficiency.
Be careful not to drive the gate too much higher than the source though, since it will damage the MOSFET.
Old 15th February 2005, 05:08 PM   #4
woow quick reply ! ! wahat you are saying makes a lot of sense ... about to high VGS the amp already has a zenner between gate and source
B.I.G
digital/pga power supply... separate or same as lm3886? geekysuavo Chip Amps 1 13th April 2009 03:43 AM
separate chassis power supply onixuser Class D 2 4th March 2005 09:42 PM
separate power supply for USB powered device joeling39 Digital Source 15 5th December 2004 11:32 PM
Separate power supply chassis- with a difference! SHiFTY Tubes / Valves 7 27th February 2003 04:32 PM
Aleph's front end separate power supply Peter Daniel Pass Labs 24 10th April 2002 10:48 PM
Page generated in 0.08877 seconds (70.81% PHP - 29.19% MySQL) with 10 queries
