Whats the symptoms of having capacitors dried?
Is age only the factor? Could they dry up faster having the amplifier plugged in the receptacle for years, but never being powered up?
OMNIFEX |
#2 |
Electrolytic capacitors can dry with time, because they have liquid inside. If they are not in use, they will dry slower. As electrolytic capacitor dries it's value will go down a bit. In my opinion, aged electrolytics sound better, just like old wine. (of course there is good wine and bad wine) Udi.
"Things should be as simple as possible, but no simpler" Albert Einstein |
#3 |
Temperature (higher) is also a contributing factor. Ambient temperature as well as ripple current. Also excessive voltage in service. Basically anything that makes the cap. get hotter will shorten its life.
Jesus loves you. |
#4 |
If the amp is not powered up, it has no way of knowing if it is plugged in or not.
#5 |
The possibility exists that the power supply may be powered all the time. Switched rails, vs. switched mains.
Jesus loves you. |
#6 |
There is a predicatable curve that shows the life expectancy of a cap at various temperatures and ripple current. That assumes continuous operation at some level which audio amps don't run. The only caps that actually see and ripple current is the main filters. Board mounted stuff doesn't usually see much ripple.
#7 |
Rock On !
OMNIFEX |
#8 |
you should search for " capacitor forming " on the net you will fin usefull information.....
according to me in an equipement in storage ( no voltage applied ) capacitor will degrade because theere is no electric effect on aluminium oxide regenerate the insulation... |
| is there anything to help dried/old paper surrounds? | freddi | Full Range | 18 | 8th February 2009 08:38 PM |
| what is the difference between silver mica capacitors and ceramic capacitors ?? | prorms | Solid State | 1 | 6th May 2008 12:38 PM |
| Dried out electrolytics in an amp. | beppe61 | Solid State | 29 | 4th February 2006 12:24 PM |
| capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors | costiss | Parts | 11 | 30th January 2003 09:32 PM |
| differences between computer grade capacitors and small can capacitors | LBHajdu | Pass Labs | 0 | 22nd February 2002 01:29 AM |
| Page generated in 0.08730 seconds (74.69% PHP - 25.31% MySQL) with 10 queries |
