Old 14th February 2005, 10:23 PM   #1
NV&H is offline NV&H  United States
Default Blocking capacitor as a high pass filter?
I would like to power a single speaker driver with an amp and need to block everything below say 100hz or so.
I'd like to build a power amp for this speaker whose design already includes blocking capacitors at its input terminals. Has anyone out there used blocking capacitors at an amps input as a 1st order high pass filters by changing the caps value?
I'd love to hear about it.
NV&H
Old 14th February 2005, 10:34 PM   #2
udip's Avatar
Almost every amplifier has an input capacitor, and this capacitor
together with the input resistor forms a first order HP filter.
To calculate the capcitor value you can use the formula:
freq = 1/(2*pi*R*C).
Hope it helps,
Udi.
"Things should be as simple as possible, but no simpler"
Albert Einstein
Old 14th February 2005, 11:14 PM   #3
Would R in this equation not be the TOTAL resistance seen by the input device?
i.e., the resistance of whatever resistor that's been added to the input path plus the resistance of the first gain device?
Thanks!
NV&H
Old 14th February 2005, 11:38 PM   #4
udip's Avatar
Yes
Albert Einstein
Old 15th February 2005, 07:20 PM   #5
azira is offline azira  United States
Yes but I think you'd be more interested in the node that is tied to the input transistor's base/gate instead of the preamp's output. You should determine R and C based on the total resistance to GND and the total capacitanc to GND from this node. So your typically R would be the Rin of the BJT/FET in parallel with the base/gate biasing resistors. The typical C is the input blocking C. If you have a non-zero or non-incredibly small output resistance from your preamp then things get complicated but it's doubtful.
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 11:59 PM
Unibox High-Pass Filter 69stingray Multi-Way 2 3rd April 2007 11:22 PM
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 02:26 AM
Low/High Pass Filter fatpower17 Car Audio 1 28th June 2004 09:45 AM
high pass filter for jx92, j-low? jfk Multi-Way 0 16th October 2003 08:32 PM
Page generated in 0.07631 seconds (70.99% PHP - 29.01% MySQL) with 10 queries
