Old 14th February 2005, 03:14 PM   #1
Mlaen is offline Mlaen  Croatia
Default Problems never end - quietscent current!
With this new design of amp I have problems with seting the quitescent current - if I increase her a bit she'll keep increasing and if I decrease her a bit she'll keep on decreasing... what could be the cause of that??? Also when I connect the speaker with no input singal I hear a noise on the output! Could these two things be connected?
NOTE.
with 'first version' of the amp I didn't have these problems but afetr I put 0.33R resistors in series with output mosfets drain I got them!
.::Mlaen::.
Old 14th February 2005, 06:12 PM   #2
edl is offline edl  Hungary
edl's Avatar
Sorry, but what/which amp do you talking about?!
Old 14th February 2005, 06:34 PM   #3
The one and only
Nelson Pass's Avatar
I think you want those resistors in series with Mosfet Source.
Old 15th February 2005, 02:16 PM   #4
My mistake, crap! I ment resistors on source!
Here's the ola amp: http://www.electronics-lab.com/proje...001/index.html
And 'new' design' (just the output stage since rest is all the same) is in attachment.
.::Mlaen::.
Old 15th February 2005, 03:24 PM   #5
DarkOne is offline DarkOne  Slovakia
DarkOne's Avatar
All you need is a thermal compensation
Replace pot in the circuit with Vgs multiplier and attach that transistor to heatsink, thats all.
Or you can increase source resistors, so difference in Vgs during heat up does not change idle current so much.
Old 15th February 2005, 04:28 PM   #6
Ok, thanx!
Which value should I choose for those resistors so that it doesn't effect the output signal?
.::Mlaen::.
Old 15th February 2005, 10:42 PM   #7
AKSA is offline AKSA  Australia
0R47 is a good value for a mosfet amp.
You won't really need a Vgs multiplier with this source resistor.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 16th February 2005, 03:15 PM   #8
Thanx for reply but it's still the same thing
Any other ideas? Perhaps a zener diode could help?
.::Mlaen::.
Old 16th February 2005, 03:58 PM   #9
PS
I just short circuted the source resistors and I have the same problem...
.::Mlaen::.
Old 16th February 2005, 04:13 PM   #10
DarkOne's Avatar
Try this -
Set the bias to 0A (turn the pot little further bellow position where bias is 0A).
Put some test signal (generator, cd) to input and attach some load on output (some power resistors, or some not expensive loudspeaker driver which can handle enough power).
Wait 5 minutes, then check if bias current is still 0A (maybe up to 100mA or so).
If so, then let the amp heat up with normal load and maybe half power (remember to use some fast fuses, it will save you money if bias will jump higher).
Then set the bias to value you want (100-500mA).
Stop playing signal/music and let the amp to cool down.
Check bias.
If bias is in range 100-500mA you won.
If bias is less than 100mA, you need even more source resistance.
If bias is higher, then stop building that amp and find something better with normal temperature compensation (this amp does not have any).
I don't understand how can anybody post schematic like this, it had to be some teoretical expert, who don't know about thermal effect on output transistors.
BTW: What's the range of idle current? (cold/warm)
no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? maxpou Solid State 31 17th June 2008 04:31 PM
Current rating and tube current draw cbutterworth Tubes / Valves 1 13th October 2006 04:42 AM
Using Ixys current regulator as current sink. G Solid State 3 16th November 2002 10:23 AM
R21? and Current Source AC Current Gain macka Pass Labs 9 20th May 2002 08:58 PM
Page generated in 0.09261 seconds (83.42% PHP - 16.58% MySQL) with 11 queries
