Push Pull driver newbie question
Old 10th August 2002, 03:39 PM   #1
Diogo is offline Diogo
Question Push Pull driver newbie question
I'm only an student, and I have built a few push pull amps, all using BJT output devices with a single ended driver, I just want to learn how the push pull driver works and how to design an amp using this stage. i want it to drive a push pull output stage.
Thanks for everybody !!!
Old 10th August 2002, 05:32 PM   #2
hugobross is offline hugobross  Europe
Nice to meet another student here!! Welcome to diyaudio.com!
What exactly do you want to know? I've put a schematic below of an amp I've just made. So which part you want us to tell you how it works?
best regards,
HB.
Old 10th August 2002, 05:42 PM   #3
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
I recommend you to take a look at the Leach amp
http://users.ece.gatech.edu:80/~mleach/lowtim/
There you have in many parts a classic design in the subject. Since you are new I gather that you haven't heard me nagging about my own stuff?
Check my monster phono amp and monster headphone amp. They are complex (according to some people) but still classic in many senses.
Se link below.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 52 pcb's in order. 27 paid.
Old 10th August 2002, 05:51 PM   #4
You got what I'm looking for Peranders, i'll take a look and tell you if I gets any doubt!
Old 10th August 2002, 05:54 PM   #5
tiroth is offline tiroth  United States
hugobross,
I asked this question in another thread without response...say you wanted to drive this amp with a balanced input...would you have to add a reciever stage, or is there still a way to take the feedback to the input stage?
Old 10th August 2002, 05:54 PM   #6
some info for Diogo:
R8 and R9 are there to limit the current through the diodes, they can also be replaced by a current source
the diodes are needed to avoid crossover diistortion, also other devices are common.
Q5 is the voltage amplifier stage (C3 reduces higher frequency oscillations), the gain is equal to R12/R13
Q3 and Q4 is a differential amplifier (R3 and R4 reduces little differences between Q3 and Q4). A differential amplifier only 'allow' different signals to go through. (i.e. if the same signal is applied to the base of Q4 and to the base of Q3 there won't go a signal to the base of Q5). When no signal applied, the diff. amp. is 'in balance' => the current through Q3 (I3) is equal to the current through Q4 (I4). I ~ (12V - 0.6V)/R5 = I3 + I4
I3 = I4 so I3 = I/2. Calculation of R7: R7 = 0.6V(Ube of Q5)/I3.
HB.
Old 10th August 2002, 05:57 PM   #7
I think it is very interenting, By taking the signal from the emiter the output devices are "looking" at a low impedance input, isn't it great when we talk about mosfet output devices? Won't we get a better low frequency responce?
Old 10th August 2002, 06:01 PM   #8
tiroth,
I've been thinking about the same thing, I think you can do it with the same diff. amp but I'm not sure.
to diogo: sorry I see now you were looking for the push pull driver and not the single driver (sorry, I've read your question too fast)
HB.
Old 10th August 2002, 06:09 PM   #9
Ok Hugobross, have you ever built one amplifier with the push pull driver?
Old 10th August 2002, 06:13 PM   #10
No, I didn't.
But have a look a previous thread:
http://www.diyaudio.com/forums/showt...5&pagenumber=2
there's also a nice driver used, maybe this driver is what you're looking for.
HB.
Push Pull driver newbie questionHide this!Advertise here!
Push-pull LF driver for up to 250Hz AdamZuf Subwoofers 0 21st April 2009 09:47 AM
Push-Pull driver stage? alexmoose Tubes / Valves 12 18th September 2006 11:38 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
In push/pull woofer mounting, Why Vas will be half that of single driver? haggy Multi-Way 7 10th December 2001 02:29 AM
