Ok, I made this PCB (attach.) but I hate all those wires to connect pots with board, so does anyone have a PCB for this project (http://www.sound.westhost.com/project97.htm) that have pots located on board and that it's designed by you (don't want to steal R. Elliot)?
In meantime I'll try to desing (again...) PCB with pots on board (so far I 've been unseccesful )
.::Mlaen::. |
#2 |
Well, if nothing else, I assume you're aware that Rod sells a PCB for the project as well.
#3 | |
I forgot to attach
.::Mlaen::. |
#4 |
You seem to know what you are doing with PC boards. What's the problem in mounting pots to them?
#5 |
I'm unable to design PCB that is relatively small (no bigger than 160*100mm) and that have pots on board... I just can't
.::Mlaen::. |
#6 |
How about a second board, same size, that piggy-backs on the component board. have pins drop into the current pot locations and mount all of your pots on the second board. Use standoffs to join the two boards physically. The whole thing can use the shaft mounts to mount to the front panel of your amp.
Just an idea.
Twisted Pear Audio |
#7 |
Thanx for reply
I have some ideas how to solve this...
.::Mlaen::. |
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| Guitar Preamp = MIC Preamp = other preamp ,,are they all same? | Paswa | Solid State | 1 | 12th March 2008 05:16 PM |
| twisted pear Preamp/other suggestions for Preamp kit | LukeDuke | Chip Amps | 1 | 1st February 2008 09:57 PM |
| Electret mic preamp - will phono preamp work? | darthmullet | Analogue Source | 6 | 12th October 2007 07:32 AM |
| wiring preamp outs on a preamp | bonsai171 | Solid State | 4 | 22nd March 2004 10:13 PM |
| Page generated in 0.08909 seconds (68.69% PHP - 31.31% MySQL) with 11 queries |
