Did u hear about Crescendo amps... ive heard that from Hunter Audio India...
Old 12th February 2005, 06:21 AM   #1
diysmartdeep21 is offline diysmartdeep21  India
Banned
Default Did u hear about Crescendo amps... ive heard that from Hunter Audio India...
what is the cresendo amps well wat ive heard that these are the only amps which drives the tripple 270mm or quad 270mm magnet based woofers.... and he said that the magnet size is overdamped...so we have to use something really powerful amp...
but what cresendo means???
why cant chip amps drive such huge drivers....?
If so velodyne uses the class D chip amps to drive their monsters...
what can class D chip amps drive the Huge magnet structed Woofers?
Old 9th July 2005, 06:49 PM   #2
hunter audio is offline hunter audio  India
hi
most probably people in chip amps will not be able to help , post this in solid state (where all the solid guys are actually ) and ull get all your repies
suranjan
Old 10th July 2005, 08:26 PM   #3
Bgt is offline Bgt  Netherlands
Crescendo was the Power Mosfet Amp from Elektor in 1982
Old 11th July 2005, 08:19 AM   #4
slackman is offline slackman  Germany
Yes,
and later on the 'Millennium Crescendo' ...
Very cool design but belongs to the solid state fraction.
mik
Old 11th July 2005, 03:43 PM   #5
Very cool design
Jep, I made dozens of them. Never a problem. Lots of mods. and rock stable. The best amp. Elektor ever made. Made all the amps. from Elektor but this 1 stayed. Still use 4 of them.
Old 11th July 2005, 07:36 PM   #6
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Wasn't it the original Crescendo that oscillated quite frequently ( or was that the other, later one ? ).
It's only audio. Member of the non modular PCB design committee
Old 11th July 2005, 09:09 PM   #7
Bensen is offline Bensen  Belgium
Bensen's Avatar
yes, jean-paul. It was the first Crescendo amp (1982) that oscillated pretty havely when used wired wound resistors. Mine amp runs perfectly since 1998.
With the Crescendo ME, I had first also a few problems wih oscillation, but these were solved by making better PCBs.
But I wouldn't know why many other amps couldn't drive these woofers, there are much better diy amps than the crescendo's.
Old 12th July 2005, 02:11 AM   #8
amplifierguru is offline amplifierguru
Account Disabled
Hi all.
I have had zero to do with on chip power amps but here's a possible theory (we physicists are good at theories) - Chip amps are marketed on power output and so this is the primary goal, reactive load driving ability which would cause considerably higher package and output stage dissipation, is not! So the output stages probably have some restrictive SOA protection included which is why they don't drive reactive loads so well.
Just a theory.
Greg
Old 12th July 2005, 06:25 AM   #9
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
This smells of dirty marketing.
Old 12th July 2005, 08:42 AM   #10
edl is offline edl  Hungary
edl's Avatar
the original crescendo schema:
http://www.audiofanatic.it/Schemi/Ti...K135_2SJ50.jpg
Did u hear about Crescendo amps... ive heard that from Hunter Audio India...Hide this!Advertise here!
O-Audio? Anyone hear from him... Todd, I think?? PHilgeman Multi-Way 1 5th December 2006 02:36 PM
Hunter needs help JimF1969 Parts 6 6th February 2006 07:45 AM
non-Pass amps youv'e built/heard BrianL Solid State 49 5th July 2005 05:59 AM
[INDIA]Building heavy duty Chasis for Power Amps. ajju Parts 11 20th November 2004 03:55 AM
Anyone heard of or used Rythmik audio Sub Amps? PaulHilgeman Multi-Way 1 20th May 2003 12:20 AM
