Hi, this may be off here but I need some help. Iīm currently troubleshooting a Yamaha RA50, which is a keyboard amp (with a built-in leslie). Itīs from around 1975, I think.
At first, the problem only showed up after the amp had been switched on for about an hour or so. Now, however, itīs there invariably... Firstly, there is a rather loud noise, with crackles and pops and the AC hum becomes pretty evident. This noise is not affected by volume or tone controls in the preamp. One can also disconnect the preamp altogether and the problem is still there, which, of course, suggests the error is located in the power amp. Secondly, there is an alarming DC offset at the speaker output of approx. -5V. Interestingly enough, however, the amp does work and sounds pretty good, if it wasnīt for this "overlayered" noise... Since itīs pretty old, maybe one should exchange all the capacitors..? Any help appreciated. Iīve attached a schematic for the power amp. Cheers |
#2 |
I you have access to a scope you can measure the ripple from the supply rails.
I would however change the small electrolytic caps first. Keep in mind that the 10ĩF at the base of TR2 is a bipolar. /Hugo |
#3 |
I just got a Yamaha RA50 that has exactly the same problem. Did you fix yours? What was the problem?
Thanks very much! |
#4 |
Hey, thatīs interesting!
Yes, I found the problem, it was one of the transistors in the input differential stage of the power amp (TR1 or TR2, canīt remember which...). Couldnīt find the right kind so I found a new equivalent pair, and they worked fine (canīt remember what they were, either, sorry). Hope this helped! Cheers Martin |
#5 |
hi
i have a yamaha ra-70r combo guitar /keyboard amp , has a fault in the amplifier power section huge hum and 3amp fuse blows , someone changed the output transistors and the collector load resistor from .47 to a 2.2ohm. this is wrong as it must be the same as the other side to produce a 0 volt dc on the speaker. so i am looking for a circuit diagram ... maybe i can fix the amp.. i checked the ra50 and is not similar. as mine has 11 transistors in all , thanks |
| Yamaha AX-390 | Predator864 | Solid State | 15 | 15th July 2011 08:36 PM |
| Yamaha cdx 900 | stex | Digital Source | 4 | 23rd January 2010 11:44 AM |
| Yamaha RA50 rotary speaker/leslie | julianw | Solid State | 0 | 24th July 2008 01:00 PM |
| Yamaha M-4 | desperateaudio | Solid State | 21 | 22nd April 2008 03:45 PM |
| Yamaha RX-777 | quasi | Solid State | 4 | 15th November 2007 12:58 PM |
| Page generated in 0.07335 seconds (84.40% PHP - 15.60% MySQL) with 11 queries |
