Dear DIYers,
I have found the attached schema in an old audio magazine. I was wondering if this schema is suitable for a simple line preamp. The voltage gain should be about 3 (if I am not wrong). The supply voltage is 60 V (single supply). Unfortunately the two BJTs are not named. Does anyone have any suggestion for a couple of suitable BJTs? Thank you very much to anyone. |
#2 |
Something like BC639/BC640 should do the trick IMO.
/Hugo |
#3 |
Dear Sir,
Thank you very much indeed for your kind and extremely valuable reply. What do you think about the schema ? I intend to replace the linear attenuator at the input with a log potentiometer and take the signal off the output coupling cap (this will be a film cap of course, like tho other one at the input). I think that this kind of circuit is called " Sziklai pair " but I am not sure. In general I am looking for a minimalist line preamp. I would like to stay with BJTs even if I understand that the Nelson Pass Bride of Zen is very very good, if well built. I don't know if this preamp is able to drive my power amp that has an input impedance of about 8 kohm. Any your further suggestion would be very much appreciated and valuable for me. Thank you very much again. Kind regards, Beppe61 Torino__ITALY |
#4 |
I am willing to bet that even an opamp circuit will sound better.
#5 |
Hi.
BC550C and BC557C work well in this circuit. Use polyester btpassed with polysteyrene for good cheap coupling caps. Super hint make the 120k with 20k from the supply decouple with a good cap and then a 100k to the base of TS7, this removes supply interaction and tightens the sound.If you are an experimenter then replace TS8 with a p chanenel fet like a BS250 and reduce the values of R33 and R34 for a lower output impedance. Chris |
#6 |
Did it Himself
Replacing the lin pot with a log pot is not a good idea, as the parallel combination of the 27k and 120k resistor bend the curve of the lin pot to an approximate log curve. I think you will be just about OK to drive an 8k load with this circuit.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#7 | |
better than any opamp....
"Things should be as simple as possible, but no simpler" Albert Einstein |
#8 | ||
Electrons are yellow and more is better!
fT > 100MHz Hfe > 100, >300 even better Min 30 V BC55x BC56x BC54x Even old BC108 will work
/Per-Anders (my first name) or P-A as my friends call me |
#9 |
Ok dear friends,
I have to reveal the little dirty secret. The schema is "stolen" from that one of the line input stage of and old but very estimable Radford ZD22 preamp. The full line stage is much more complex including also tone control section (I personally hate it). Unfortunately, but as usual, the schema doesn't report the BJTs' codes. So the search is open for suggestion. I think that TS8 should be cooled with a dissipator. So a TO92 case BJT wouldn't be the best option, I think. I was thinking about the 2SA968. An handy TO220 device. Is it too much ? Thank you in primis to the Radford designer (who is he/she I really don't know) and then to everyone who takes part in this discussion. I am very curious in how this extremely simple stage can sound. Really an op-amp based preamp would be better ? Don't know. Kind regards, Beppe61 |
#10 |
Dear Moderator,
If what I am writing is not allowed please forgive me and delete the following message. Dear friends, The original BJTs are: TS7 = BC107 TS8 = BC303 The BC303 must be cooled. So I would like to replace the BC303 with a TO220 case Toshiba 2SA968. Is it possible without other modifications to the circuit ? Kind regards, Beppe61 |
| Looking for schematic of 26 WOT Preamp | lanew | Tubes / Valves | 4 | 8th April 2009 04:40 AM |
| Need help to check out this preamp schematic. | pchw | Tubes / Valves | 7 | 27th December 2007 07:47 PM |
| look for schematic of 12v preamp ??? | prorms | Tubes / Valves | 2 | 25th October 2007 07:33 PM |
| Looking for Schematic using KC3 Preamp ? | calico88 | Tubes / Valves | 0 | 3rd July 2006 04:00 AM |
| Preamp schematic... | Guiness | Tubes / Valves | 17 | 12th February 2004 02:37 PM |
| Page generated in 0.10857 seconds (78.34% PHP - 21.66% MySQL) with 11 queries |
