I have just finished building a v4.5 leach amp . All the parts are recommended , ther is +/- 57v idle and 54 v loaded at the rails. When fed a 1 v 1khz signal the output wave is perfect and there is approx 37 v at he output terminals. However when I hook up an 8 ohm 100 watt resistor the output siganl drops right off in about 10 seconds and stays there. I suspect a problem in the protection circuit however both channels react the same . Any ideas?
Thanks Ed Q. |
#2 |
Sound like power supply trouble to me - not sure though.....
What is you railvoltage when you apply the 8 ohm load? What is your transformer VA rating if you know? If you are unsure, how much does it weigh? \Jens |
#3 |
Under load there is +/- 54 v , adequate according to specs ,it is an 800 va toriodal transformer. I have another one available to test.
#4 |
Swapped in a 700 va 80 vct transformer and now all is well .
Thanks for the input , it got me looking in the right place. |
#5 |
Hi, glad to hear the problem went on holiday with the transformer swap.
But what was the problem? regards Andrew T. |
#6 |
Control again values of all devices - if makes both channels the same, problem will be there.
#7 |
Problem was found in a small fault in windings of transformer, center tap was not going to ground properly , loss of voltage under load.
| possible leach problem?? | rtate | Solid State | 7 | 23rd October 2008 04:35 PM |
| Leach amp problem | Curioprop | Solid State | 95 | 1st September 2008 09:58 AM |
| Problem with leach amp | AudioG | Solid State | 1 | 8th June 2005 02:40 PM |
| problem with leach amp | xxsmiffxx | Solid State | 5 | 25th February 2005 07:50 PM |
| Leach amp problem | Ed LaFontaine | Solid State | 3 | 19th July 2004 12:04 AM |
| Page generated in 0.08925 seconds (71.10% PHP - 28.90% MySQL) with 10 queries |
