Hello
i got 2 trafos 50-0-50v and 450VA from an old SONY ES power amp.
i like to build the OPTI-MOS amp seen here
http://www.sealelectronics.com/kits/index.htm
but it sems my railvoltage will be to high. for the VA rating. is there any way to lower the rail voltage? using regulation? or something else? so i will get closer to 50 volt rails.
tnx
tnx
your +-70v rails will give about 200w into 8r and just under 300w into 6r. The 450 VA rating should be OK at these loadings even driving a full range speaker.
Into 4r the voltage will sag badly but you can ameliorate this with extra capacitance in the DC filter. This will not cure it.
It will not suit a stereo amp although many manufacturers may well supply a similar size as yours and quote short term outputs.
Check with your supplier about changes to higher voltage transistors.
regards Andrew T.
regards Andrew T.
AndrewT said:Hi,
regards Andrew T.
tnx agin
this is for 1 450VA trafo per Channel correct? how many watts in 4 ohm? and how do you calculate it?
you can expect a peak output voltage of about 5v to 10v below Vrail with BJT and 10v to 15v below Vrail with FET.
The power is Vpk * Vpk / 2 / R.
Your Vrail will drop slightly for 8r load maybe 5v, but will drop much more into 4r maybe 10 to 15v below unloaded Vrail
Vpk (4r) could be as low as 45v giving 253w, way below potential 400w for a stiff PSU.
regards Andrew T.
regards Andrew T.
- OPTI-MOS using 50-0-50 450VA TRAFO
