#61 | |
Right, that's it! Actually, Mr Hawksford started out in a similar way in his paper, and then zoomed in on the special HEC case. One reason was that because only a gain of 1 is required, he could do it with a few transistors: use the emitter to inject a currect proportional to error, and use collector current to develop correction voltage. Since Ie = Ic (almost) using equal resistors gives the HEC gain. And those transistors are already there - in the bias circuit. But anothe advantage I see is that because of the unity gain around the output stage, there is absolutely no stability issue to worry about. Even if you would have to use some extra components, for me it still is a very attractive topology. I hate oscillating amplifiers, and those compensation things like Vas Cdom and what have you cost you performance. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#62 | |
One thing I noted is that there is a difference in distortion depending on whether you are above or below unity: The phase of the distortion products wrt to the main signal switches 180 degrees when you go through the unity gain point (where they should be zero in theory). I was thinking at that time to use it to cancel distortion in a bridge type amp, you know, one just below unity and the other just above, thinking that would in practice be easier to realise than exact unity. But I couldn't get it to work satisfactorily. Jan Didden
#63 | |
WRT stability, agreed, however I believe you probably still need a LR OP decoupling network for stability into cap loads. Anyone else here know if Hawksfords EC can drive cap loads direct (obviously without global FB connected)? IMO, it is a sonic advantage not having to use OP decoupling network. Cheers, Terry |
#64 |
I've driven Quad ESL63 loudspeakers with my amplifiers (with Hawksford error correction and no global feedback) without series L in the output and without Zobel (Boucherot) filter. No stability problems.
Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973 |
| Hawksford output error correction circuit? | Jorge | Solid State | 96 | 12th December 2011 11:31 PM |
| Re: New error correction amp | mefistofelez | Solid State | 12 | 7th October 2010 06:55 AM |
| error correction et al' | sq225917 | Digital Source | 4 | 7th August 2007 10:16 AM |
| Bipolar OP Stage Error Correction | Bonsai | Solid State | 13 | 5th December 2006 06:08 AM |
| Page generated in 0.09542 seconds (74.79% PHP - 25.21% MySQL) with 11 queries |
