I'm new here and I've got some questions: Some time ago I bought this power mixer (2x150W @ 4Ohms; Bridged 1x300 @ 8Ohms): http://128.134.140.230/english/product/ca-6215.html Well, the whole amp (not the pre-amp) got destroyed and i tried to fix it (all 8 power transistors were destroyed and some other parts) but i had no luck - it's kinda hard working without the original schematic and a lack of original parts. So I thought about creating my own amp (of course, i'll keep the preamp and mixer) as i dont wanna pay too much for reparing. since the heat sink had holes for 8 transistors i could easily install TDA7293s instead. So this was my idea: - Change the transformer (2x40 ~ V is too much) and replace it with my 2x30 V ~ . Is the voltage low enough ? - I first only want to build one channel using 4x TDA7293 (4 parallel and bridged (2 and 2)) - How much power can I expect ? It will be more than original 150@4Ohms, right ? I'm not big amp expert, so i thought this would be a kind of easy solution ? What do you think ? Thanks PS: Some electronic parts store (germany) offers TDA7294V and TDA7293 (without "V") - does such a without-V-version exist at all or can i expect it to be the TDA7293V ? |
#2 |
TDA7293 it is a very good circuit, but in this case it is not the best option . You can make an amplifier with two STK4048 and you can use original transformer. It would be cheaper solution. Try to make a search on this forum and you will get many topics about STK4048. I know a pro-amplifier with STK4048 [ 2x200w/4ohm ] wich is runing for 5 years every night in a small nigh-club.
#3 |
Right, the STK series is good and quite convenient to use. But you have to be careful about the heatsink. The hybrids dissipate a lot of power, so take care to have a big enough heatsink or use fans. You can easily burn your fingers at the heatsink (my experience!).
If necessary, you will find a lot of data sheets at http://www.datadart.com/al/sanyodata.htm Good luck! Herman P.S. In Germany, most of the circuits can be obtained at Reichelt electronics, check at www.reichelt.de |
#4 |
I would suggest the "UB" way.
You get all the necessary information and the parts (in german, also pdf) from SCHURO http://www.schuro.de/preisl-hiamp100.htm and from the constructors site http://www.ub-elektronik.de/elektronik/index.htm The TDA7293 is kind of tricky for newbies, so be careful with bridged - or better - paralleled versions. At the Audiomap forum http://www.audiomap.de under "Selbstbau-Elektronik" you will find guys who have already gained lots of experience. hope that helps Klaus |
#5 |
Thanks for the information.
Looks like Reichelt (reichelt.de) doesn't have the 4048 any more (Yesterday I found the V version, but not the XI) - Today the only thing >4044 I found was the STK 4050 V. Is it any good ? And the TDA 7293 is available. I guess I have to replace the transformer anyway cuz it is probably not power enough for a more powerful amp. And I have a 2x30V ringcore transformer here anyway. Well, I just want a simple, powerful and stable amp |
#6 |
Account Disabled
the STK4048XI is powerful then TDA 7293
and more high q..... the sound on stk4048XI batter then TDA 7293........ if u want more power : STK4050V - 200W LM12 (in Bridged) - 300W - very very simple!!!! to build PA03A - 1000W the site - http://radvs.boom.ru/ims-unch4.html PA05A - 300W lm 12 : |
| tda 7293 and tda 7294 help | sagarverma | Chip Amps | 84 | 19th May 2012 03:40 AM |
| Power Amp IC TDA 7293 | headsavers | Parts | 2 | 22nd September 2006 01:39 AM |
| TDA 7293 clip detector - how ??? | Cro maniac | Chip Amps | 1 | 10th March 2004 07:35 AM |
| Question about bridging TDA 7293 | Cro maniac | Chip Amps | 4 | 6th February 2004 09:10 PM |
| Appropriate components: LM 3886/ TDA 7293/ + | rick57 | Chip Amps | 1 | 23rd December 2003 09:03 PM |
| Page generated in 0.08792 seconds (83.56% PHP - 16.44% MySQL) with 11 queries |
