Old 2nd February 2005, 01:28 PM   #1
jackinnj's Avatar
Default Optimum OpAmp Noise Performance
The current issue of EDN carries a Design Note from Linear Tech with graphs relating input resistance values AND noise performance -- giving suitable LLTC opamps -- it isn't always the correct decision to use an LT1028 or LT1115.
Of course, it is Linear so the ADI and BB parts aren't included.
Here's the link:
http://www.linear.com/pc/downloadDoc...21,P2440,D6539
Old 2nd February 2005, 01:48 PM   #2
scott wurcer's Avatar
Try using a MM phono cartridge as your source resistance, pretty easy to actually do (I have). Removing the stylus gets rid of vibrational problems if any. The results may be surprising.
Properly load the cartridge too of course.
Old 3rd February 2005, 06:50 AM   #3
mfc is offline mfc  United States
Heres a question on noise.
I've seen JFET input stages where the gate bias resistor can
be huge (sometimes like 100Gig).
Since the article says resistor noise is .13*sqrt(R) then
for a 100Gig resistor that would be 41uV/sqrt(Hz).
Does that mean that this is a real bad idea to have a bias
resistor that large...or is this resistor in parallel with the source
resistance, so it is essentially not a factor?
Old 3rd February 2005, 01:38 PM   #4
This would usually be in an application with a capacitive transducer such as a condenser mic. The capsule capacitance rolls off the noise at a low frequency. For instance a Nakamichi CM300 capsule measures 55pF and uses 1GOhm bias on a 2SK118 JFET. That's about a 3Hz roll off, but your working against the 4000nV/rtHz of the 1GOhm R so the mic will show a rising low frequency noise spectrum. Now if you think about it since the noise of the resistor goes up as the square root of R and the pole goes down as R, you win with a bigger R (i.e. a 100GOhm R will have 1/10th the noise at some low frequency).
Old 3rd February 2005, 02:25 PM   #5
Electrons are yellow and more is better!
peranders's Avatar
Default Re: Optimum OpAmp Noise Performance
... exactly, you most know the info behind the figures also. Mosfets are very low noise in HF circuits but not for mic amps... it depends.
/Per-Anders (my first name) or P-A as my friends call me
Old 3rd February 2005, 07:23 PM   #6
Originally posted by scott wurcer
...(i.e. a 100GOhm R will have 1/10th the noise at some low frequency).
I think you got this result because the capacitor forms a low
pass filter in parallel with the bias resistor, so a larger resistor value provides more attenuation...
At the same time the 100Gig contributes sqrt(10) times more
noise of ite own. Since this goes up by a half power, the net effect
is that the filter effect dominates and provides lower noise?
If there is no capacitor, would a really large bias resistor
be a bad idea? Also would LTSpice noise analysis model
the effect of large bias resistors?
Old 3rd February 2005, 07:47 PM   #7
You can create a non-physical abstraction with any simulator. A 100GOhm resistor has a 3Hz pole with .5pF so any real board or circuit would show noise roll off. The simulator will work fine with large resistances, but any real amplifier will have a pF or so of stray capacitance.
Old 3rd February 2005, 08:38 PM   #8
Ahhh...now it makes sense. Thanks Scott!
Old 5th February 2005, 08:03 PM   #9
Playing around with LTSpice, I got this (somewhat)
non-intuitive result for noise in a resistive voltage
divider.
Best overload performance RIAA opamp pre? leadbelly Analog Line Level 1 5th February 2008 07:05 PM
Ultra-High performance OpAmp-based MOSFET Power Amp tlf9999 Solid State 20 7th September 2005 09:41 PM
jitter and noise performance of 74xx AC and VHC series? patwen Digital Source 2 22nd November 2004 12:31 PM
Optimum Opamp setup 5th element Solid State 12 12th July 2003 04:57 PM
New low noise opamp jackinnj Solid State 0 27th August 2002 06:51 PM
Page generated in 0.10614 seconds (80.03% PHP - 19.97% MySQL) with 11 queries
